Here's how the installation went.
Passenger side first.
You will need to remove the Battery cover surround & the lower windscreen cowl cover.
The connector is located between the wiring harness & the Popper mechanism
Its pretty tight in there & I have fairly big hands so I decided to remove the popper for access
Pictured now with the canceler connected
Back together & cable tied in position
Now The Drivers Side
Remove the Brake cover & surround to expose the ABS Unit.
The Bonnet popper connection is right behind it.
I didn't need to remove the lower windscreen cowl on this side, I just propped it up to allow a bit better access.
Shown with the popper disconnected.
Canceler fitted
All cable tied safely.
Everything Back in Place, Job Done.
Edited by mycarhasposessedme
