Gktech dished 350mm steering wheel, comes with horn button, was mainly used on racing sim rig - $50
Gktech GKTech v2 front castor arms to suit S13/R32, was in the car for 1 track day - $100
Sparco Sprint Junior, smaller sized fixed back bucket seat and in good condition, is missing plastic frame where the seat belt goes on left side but doesn't effect the seat at all, Seat only no rails. - $200
Located in the Western suburbs
  • 4 weeks later...
  • 3 weeks later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
