My Box of Things Sale, R34, 180sx, V35, RB20, SR, CA. Located in Tascott NSW 2250
Willing to Post, Pictures Available, Msg 04049212eight Seven or PM
R34 Stuff
R34 standard filter box bottom half only $10
R34 Standard Arms $Free
R34 GTT stockies $150
R34 Dash $50
R34 GTT Spoiler $80
R34 Coupe doors $50 each
R34 interior trim pieces $20 each
R34 Viscous Diff Centre $50
R34 Standard Gauges $60
R34 Rear Hicas Module $40
180sx Stuff
Sr/Ca gear stick/knob/plate $10
CA Manifold $10
180sx Black tail lights $100
180sx headlights $50
180sx pig nose front bumper $150
180sx rear bumper $50
Ca/Sr non abs tailshaft $50
Sr 20 carbon pod filter Cover $20
Ca18 a/c compressor $20
5 Bolt Dump pipe into 3 bolt $40
S14 Standard Fuel Pump Assembly $5
Rb20 engine complete in bits all parts available $125 for the lot
V35 Stuff
V35 Front Bar $250
V35 Rear Bar $250
Universal Parts
1x 18x8 +42 and 1x 18x9 +33 PDW Replay no tyres $20 each
New Nos Pod filter $5
Malpassi FPR $20
Intercooler 600x300x76 3” in/out $100
Hi there,
I'm after the following if you have any?
- GTR front lip
- GTR wing (must be genuine, 3pc wing. not fibreglass shit, got one alrdy!)
- RB20 coilpack cover. Prefer factory ones but will consider tidy aftermarket ones that cops will take nicely to!
Located south east Victoria, so will require shipping.
Sorry only have 5 RB20 coilpacks as I dropped one and the plug part broke so I just put it in my bin. coilpacks work just fine but I've upgraded to splitfires.
5 Coilpacks $30
  • 9 months later...
  • 3 weeks later...
My Box of Things Sale, R34, 180sx, RB20, RB25, S15, R32, SR, CA. Located in Tascott NSW 2250
R34 Stuff
R34 Dash $50
R34 GTT Spoiler $80
R34 Stock Turbo Manifold $30
R34 5 Bolt Drive Shafts $100
R34 5 Bolt Diff Half Shafts $50
180sx Stuff
CA Manifold $10
5 Bolt Stainless Dump pipe into 3 bolt $40
S15 Front Brake Rotors Machined and Sealed $50
R32 AWD RB20DET ECU $50
Updated 28/03/2016
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
