Faked an STi into launching behind me before I had the 220rwkw retune. He was 3 car lengths behind me to launch hard so I took off slow so his awd launch didn't help, then handed him his slow ass on a plate :cheers:
In the wet tho, a standard NA Impreza would own me.
Horses for courses as they say but never overestimate just what a poorly built piece of junk they are.
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-931971
:cheers:
I still want to know WHAT THE HELL HAPPENED TO THE OLD ONES?! like they were released in about 1994(?) in australia and at the time I remember quite a few on the roads then, and yet you hardly ever see one before about 1998 anymore. Something doesn't add up!
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-931997
I have loss to a rex STI once at the light when my clutch was total f$&Ked, but normally they are just breakfast to me!!! i would say rex driver will scare to see cars with four round rear lights beside or around him at the traffic light >.
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-931998
:cheers:
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-932001
:D
Hahaha dude... The MY98 front is THE mod to do your old WRX...
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-932932
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
