Faked an STi into launching behind me before I had the 220rwkw retune. He was 3 car lengths behind me to launch hard so I took off slow so his awd launch didn't help, then handed him his slow ass on a plate :cheers:
In the wet tho, a standard NA Impreza would own me.
Horses for courses as they say but never overestimate just what a poorly built piece of junk they are.
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-931971
:cheers:
I still want to know WHAT THE HELL HAPPENED TO THE OLD ONES?! like they were released in about 1994(?) in australia and at the time I remember quite a few on the roads then, and yet you hardly ever see one before about 1998 anymore. Something doesn't add up!
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-931997
I have loss to a rex STI once at the light when my clutch was total f$&Ked, but normally they are just breakfast to me!!! i would say rex driver will scare to see cars with four round rear lights beside or around him at the traffic light >.
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-931998
:cheers:
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-932001
:D
Hahaha dude... The MY98 front is THE mod to do your old WRX...
https://www.sau.com.au/forums/topic/45645-rexetr/#findComment-932932
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
