Lots of stuff up for grabs here, all this gear is either brand new or in good condition!
6 Denso 700cc 11mm Top feed injectors $400
HKS Fuel Rail $250
HKS Exhaust + High flow cat $150
Ghost auto ss 100 micron filter New $80
HKS Heat Shield New $150
Aftermarket Industries twin Bosch 044 Bracket New $50
Genuine Bosch 044 New $150
RB26 HPC Coated Plenum + Throttles $300
1 x Z32 AFM + Plug and k&n filter $200
Haltech 3 bar map sensor $60
K&N Filters 2 x 1/2" 1 x 1" $30 each
Thanks for looking
Hi there,
I'm after the following if you have any?
- GTR front lip
- GTR wing (must be genuine, 3pc wing. not fibreglass shit, got one alrdy!)
- RB20 coilpack cover. Prefer factory ones but will consider tidy aftermarket ones that cops will take nicely to!
Located south east Victoria, so will require shipping.
you wouldn't be able to measure if the middle breather in the middle could slip on to a 20mm end would it? cheers
Hey mate the two on the left are 1/2" just in different packaging, i cant get a accurate measurement unless I open it but selling as brand new unopened
Cheers
  • 1 month later...
Hks rail sold.
Still for sale
Hks shield $150
RB26 plenum with throttles $300
Aftermarket Industries mount $50
Z32 afm $200
Ghost auto filter $50
Haltech sensor $50
Will include postage
Cheers
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
