Hi guys
i'm selling most of my spare car parts I have accumulated over the years due to new commitment.
BNR32
Front Strut Bar, manufacture unknown there is some scratches - $65
Front Strut Bar, manufacture Aiba, - $65
Front Strut Bar, Cusco, - $85
Rear Strut Bar , Cusco - $85
Floor Cross Bar, Do-Luck - $250
Genuine weather shield NEW two pairs - $350 each pair
Blitz twin core radiator in good condition, no leaks, comes with fan shroud and radiator cap $ 390
Tein Comfort Sport, 16 Stage damping, 5k and 4K spring Rate no leaks or Knocks in good condition - $1400
Ohlins Full Tap 20 stage adjustable coilover with hyper coiler springs, 9k and 7k spring rate, no knocks or leaks, very good condition - $2650
Trust Oil cooler kit in very good condition $350
HKS Oil Cooler Kit $400
Ikeya Formula adjustable camber Arm Rear, Near new condition $410
Nismo 600cc Injectors good condition $520
Greedy 4pcs intercooler pipe kit $370
ATS twin carbon plate clutch push type comes with flywheel, both clutch plates are at thickness of 3.9mm plenty of life left in them - $820
Nismo Front and Rear Sway bar set front sway bar 22.2mm rear is 27.2mm - $500
Cusco 7 point roll cage in good condition with everything you need for fitment, around the dash. - $700
Okuyama 6 point though dash Roll cage in good condition everything everything you need for fitment - $520
Stainless steel front pipe two 70mm to 80mm brand unknown, no leaks - $200
Nismo GT Pro LSD 1.5 way final gear ratio 37:9 in very good condition - $1000
R32 GTST GTS
Genuine Weather Shield New - $240
BCNR33
Genuine weather shield NEW - $350
Ohlins DFV coilovers, travelled 3000kms 9k and 8k spring rate 20stage adjustable near new condition $2700
HKS Hypermax 4 GT 30stage damping 8k and 7k spring rate in good condition, no leaks or knocks $1600
O2 sensor x2 $120
ECR33
Nismo G-attack s tune 4 stage damping, no leaks good condition $950
Tein Type RS circuit master coilover 16stage damping and rebound adjustment, good condition 10k and 9k spring rate $1750.
Ganador Exhuast 80mm to 90mm tail is 120mm. no leaks, good condition $ 550
BNR34
Nismo R tune Air duct, Brand new - $490
Tein Street Flex Coilovers 16stage damper adjustable 8k and 7k spring rate no leaks or knocks good condition - $1050
Kakimoto Cat back Regu06 80mm to 90mm and 110mm minor scratch marks but no leaks - $620
ER34
Twin core Radiator, 50mm core size no leaks and good condition - $ 190
Trust Oil Cooler kit good condition - $500
Other
Nismo Clear side indicator Brand New - $90
Nismo Carbon fiber inside Mirror cover Brand new R32 and R33 - $260
Can ship anywhere at buyers expense.
I will be uploading the photos shortly
Please do no hesitate to PM me
thank you
Hi Roy,
For my BNR32, I'd like to buy the...
* Nismo F&R sway bar set if HD links/bushes are top condition. Pics?
* Nismo c/f interior rear vision mirror cover
...please.
I can pick up from Mortdale. Ta
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
