Parts still available guys, all prices negotiable!!
BNR32
Front Strut Bar, manufacture unknown there is some scratches - $65
Front Strut Bar, manufacture Aiba, - $65
Front Strut Bar, Cusco, - $85
Rear Strut Bar , Cusco - $85
Genuine weather shield NEW Suits BNR32 and R32 Two door - $240
Blitz twin core radiator in good condition, no leaks, comes with fan shroud and radiator cap $ 390
Tein Comfort Sport, 16 Stage damping, 5k and 4K spring Rate no leaks or Knocks in good condition - $1400
Ohlins Full Tap 20 stage adjustable coilover with hyper coiler springs, 9k and 7k spring rate, no knocks or leaks, very good condition - $2650
Trust Oil cooler kit in very good condition $480
Ikeya Formula adjustable camber Arm Rear, Near new condition $410
Nismo 600cc Injectors good condition $520
ATS twin carbon plate clutch push type comes with flywheel, both clutch plates are at thickness of 3.9mm plenty of life left in them - $820
Cusco 7 point roll cage in good condition with everything you need for fitment, around the dash. - $700
Okuyama 6 point though dash Roll cage in good condition everything everything you need for fitment - $520
Stainless steel front pipe two 70mm to 80mm brand unknown, no leaks - $200
Nismo GT Pro LSD 1.5 way final gear ratio 37:9 in very good condition - $1000
BCNR33
Genuine weather shield NEW - $350
Ohlins DFV coilovers, travelled 3000kms 9k and 8k spring rate 20stage adjustable near new condition $2700
HKS Hypermax 4 GT 30stage damping 8k and 7k spring rate in good condition, no leaks or knocks $1600
O2 sensor x2 $120
ECR33
Nismo G-attack s tune 4 stage damping, no leaks good condition $950
Tein Type RS circuit master coilover 16stage damping and rebound adjustment, good condition 10k and 9k spring rate $1750.
Ganador Exhuast 80mm to 90mm tail is 120mm. no leaks, good condition $ 550
BNR34
Nismo R tune Air duct, Brand new - $490
Tein Street Flex Coilovers 16stage damper adjustable 8k and 7k spring rate no leaks or knocks good condition - $1050
Kakimoto Cat back Regu06 80mm to 90mm and 110mm minor scratch marks but no leaks - $620
ER34
Twin core Radiator, 50mm core size no leaks and good condition - $ 190
Trust Oil Cooler kit good condition - $500
Other
Nismo Clear side indicator Brand New - $90
Thanks
Many thanks Roy for the F&R Sway Bars. > Fitting these now.
And thanks too for the C/F Rear Vis Mirror Cover.
Great to deal with...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
