Not done much about this. Today took the pedal switch out. Multi meter test says it works fine. The lights are still on after taking out the fuses and relays.and the switch.
Is there any way of getting an English/Strine wiring diagram? Anybody out there had this trouble???
https://www.sau.com.au/forums/topic/456476-stoplights-still-on/
So your saying that the Stop lights are on, Yet you have removed the Fuse, and checked the Switch as fitted to the pedal arm.
Question for you, is the switch etc on the ground side of the light ?? to if so then you have a short to ground somewhere check this earth your Multimeter and apply the Positive lead to the switch in Continuity Mode and if you get the buzzer sound (multimeter ) then this likely indicates that the switch is on the ground side of the bulb.
If this is the case then it sounds like you may have a short somewhere that is holding the lights on .
The intriguing part is the Fuse is out and you still have light on,
Do you have Fog Light's and High intensity Tail lights ? there could be a voltage leak there and this is why the lights are on independent of the fuse.
The Above is based on general vehicle wiring and may not be directly applicable to the Stagea either.
  • 1 month later...
Have been all over checking and found there is a short somewhere in the tail light harness. I will have to start from the back and pull out all the interior linings and hope I find a wire that is bared and shorting.
Handy little gadget the multimeter.
