2015 Sau Qld Annual Charity Cruise - 19/07/2015
2015 SauQld Annual Skyline Charity Cruise
Description:
It's that time of year again ladies and gentlemen, the Annual Skylines Australia QLD Charity Cruise!
This year we are helping out the Beyond Blue.
We will be meeting at the the Nerang train station car park. We will also be holding several raffles with profits going to Beyond Blue.
As this is a charity cruise we will be asking for a minimum donation of $20 per car.
Being a cruise, there is to be no speeding or unlawful behaviour. The club will be on public display and anyone caught breaking the rules will be asked to leave.
This is a great cause and year after year we are able to demonstrate our strength as a group and assist those less fortunate in a positive manner.
Come along for the ride and have a great day!
We will be meeting at the the car park at Nerang train station and cruising out to Darlington Park for a BBQ lunch. The BBQ will be a gold coin donation and we will also have cold drinks available, all profits from the BBQ will also be donated to Beyond Blue.
​The cruise route is available HERE
Date:
Sunday, the 19th of July.
Time:
9 AM arrival at the meeting point for a 10 AM departure.
Cost:
$20 per car plus any fuel/food you use/eat.
Requirements:
This is one of the only events we run with vehicle requirements but as this is a Skyline charity cruise we do have several.
Your car must meet 2 of the following 3 requirements:
1. Be manufactured by Nissan/Infiniti/Datsun/Prince
2. Be sold as a Skyline
3. Be powered by an RB engine.
Eg: A Nissan Silvia powered by an RB25 would be eligible as it meets two criteria
A Toyota Supra powered by an RB26 would not be as it meets one criteria only
The only exemption to these requirements is the R35 GT-R.
Let's all join together and make this huge!
Look forward to seeing you there.
  • 4 weeks later...
If I've worked out my rotating 2 week eoster I believe I'm not working that weekend, so at this point in time im in, looking like atleast 2 tanks of fuel for this chariety cruise. The hike from home to the start point is longer then the actual cruise. XD
  • Like 1
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
