Hi All,
Asking for an expression of interest in some parts I've got on my car.
Located in Melbourne's northern Suburbs
Unfortunately due to a somewhat recent fatality involving a car, my family has put alot of pressure for me to sell my track car.
which was only recently finished and has only seen one track day.
Essentially my parents are evicting the car from the garage or evicting me from the house...
Not too keen on parting it out, but sadly getting alot of pressure.
Everything on the car can be stripped and sold.
Not really sure on the prices on most of these parts but just trying to recoupe some of my money spent...
R33 GTST Turbo Brakes and rotors. $500
Manual LSD diff (Has been welded) $200
RB30/25DET Engine Conversion ($4000)
Stock Rebuilt RB30 Bottom End, Head has been fully checked and freshened up before being put on the RB30 Bottom end.
(cam balancing, x rayed, valve springs tested, valve seats reground, new seals, hot bathed, decked, new oil lines, minor porting)
Comes with HKS FCon V ECU
HyperGear GT30 Turbo ($900) no shaft play, nearly new..
RB25DET Gearbox + 6 Puck Ceramic Cushion Button Clutch ($1900)
FMIC + Piping to suite rb25 stock plenum ($400) Few bent fins from road travel.
3" Turbo Back exhaust with zero cell Catalytic converter... ($600)
Hydro handbrake ($50)
Everything on the car is up for grabs.
Would also consider cash offers for the full R33 GTST RB25/30DET. So please inbox or text.
No interior is in the car!
My number is 0423644641
Only issue on the car is the injectors are still stock GTST ones and are maxing out.
Photos to be added tomorrow.
https://www.sau.com.au/forums/topic/456507-r33-gtst-fire-sale/
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
