hey SAU ! im a new member here so if this is in the wrong spot admins please move!
iv owned my 94 r33 gtst s1 for about 3 and a half years now and my good friend before me had it for 5. ever since he has owned the car the hicas light will stay on and the hicas will not work!. but every once so often (normally after a rain storm) the next morning when i start the car the hicas light will be off the steering is light and hicas is fully working. so go to the gas station shut it off restart it and bam hicas light heavy steering, the hicas is no longer active.
now i know alot of you will say just get a lock out bar. but id really like to find out this problem before resorting to a lock out bar ()not that im agianst it im just super interested in the hicas system its self) no one in my area (canada) knows anything about hicas systems. so i thought i could pick the brains of a few more experinced guys.
i have tryed getting it to go into diag. but its never worked for me even one day when the hicas was active i tryed it and nothing.. (either im doing it wrong. or its just not going into the diag.)
any help would be awesome. thanks SAU
https://www.sau.com.au/forums/topic/456510-hicas-problem-r33-s1-gtst/
How are you trying to get it into the diagnostic mode?
The HICAS system and the low speed steering assistance are tied together as you've found out. There are speed sensors in front hubs and the steering angle sensor behind the steering wheel which are crucial. In the R33 the system is electronic so maybe there's a bad connection somewhere. Take out the HICAS ecu and pop it open to see that inside everything is ok, as sometimes a screw can get loose and it can create electrical shorts.
Hence why I asked about an aftermarket wheel - because if the boss for the wheel does not have the drive peg for the steering angle sensor you;
a) get a HICAS fault and light on,
b) can't get it into diagnostic mode because the bloody steering angle sensor is needed as part of the song and dance.
The best answer when trying to diagnose this shit is to take it to a workshop with a decent scan tool (a Nissan dealer at the worst, any good general mechanic otherwise) and plug it into the Consult port and interrogate the HICAS CU directly.
I would also check all the sensors front and rear just to make sure everything is connected properly. Would I be correct in assuming the front steering rack on a S1 has a sensor as the S2's do. You would be so pissed off if turned out to be just a crappy connection or a frayed wire because it does work sometimes.
Cheers
Neil.
hey guys sorry for the long reply. i belive the steering wheel was changed out to a stock r32 steering wheel. ill go over the sensors once i can get it into my buds shop. im thinking its a stupid connection and that would be why on more humid/rainy days it works but on warm ones doesnt. thanks for all the fast replies ill go over most of this and let you guys know whats up.
Check steering wheel sensor as suggested
If you have heavy steering when driving slowly it may be the HICAS ECU itself. I had this problem (mind you i have a lock bar installed) and it was just an ECU fault. Sounds similar to yours. Usually the first time i drove it for the day it all worked then as soon as i parked up went and did something and came back, started the car - heavy steering
I bought another ECU for about $50 second hand (was actually a newer model HICAS ECU) and has been fine ever since
Ideally, if you know someone else with a 33, swap the HICAS ECU's and see if your car starts working perfectly and their car starts playing up. That way you can confirm or rule it out without spending anything
Edited by 89CAL
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
