Fibreglass & Carbon Fibre Parts For Nissan R & S Series,evo's, Toyota's Etc - Round 5 Group Buy!
sskylinee - added to the list.
so far have the minimum requirement for GB to go ahead, 2 more weeks left to get in on this group buy so spread the word. the more people on board the more we can save.
if a part is not listed for your S or R series Nissan, EVO, WRX, Supra ETC, shoot me a message and i'll have a look to see if it's available.
Cheers
michaelk, what are the side skirt rear extensions, do you have pics of that?
pods look like these
http://knightracer.com/blog/wp-content/uploads/2010/03/Bryan_R32GTR_029.jpg
its trust style not top secret
bonnet lip is just a n1 replica in fibreglass, as the oem foam/plastic one warps and loses its shape,
could you please put me down for the following items for r32 gtr:
R32 GTR TS style rear pods - $100
nismo style bonnet lip - $50
twin A pillar gauge pod - $90 (could you specify hole size?)
Dobz, you've been added to the list
michaelk, added.
a pillar gauge is either 52 or 60 just need to specificy when ordering or i can ask to leave it blank and you drill your own.
i should also note that the 32 and r33 bonnet lips are solid not hollow like others available on the market.....
Yep that's it.
Put me down for a set of those in CF (260) and an Abflug style front diffuser in CF also (think 300)
Thanks.
okooko, done!
perhaps you and sskylinee can communicate with each other and if you guys are near by, i could get them shipped to one address to save costs :)
couldn't send you a PM haha.
I work at Eastwood. Happy to have it sent either to my work here and reception to take it or to yours at unley.
Hey dori34 I have contacted okooko and we are just going to combine postage and have the items posted to my address.
  • Like 1
    • If you have a Nissan from Japan and model year is from 2016 to 2024, just say you have an Infiniti Q50 4 doors... Why are telling you have an import?
    • It's definitely not firing order. But I think it should also be made clear that the output that gets fired is the one that corresponds to the input that was switched at the ECU. So you could scramble them up totally so that the numbers meant nothing, and so long as you had the inputs and outputs matched up, you'd be fine. The reason I make that point is that blanket statements about what it is supposed to be don't always hold out in a world where there's been 30 years for the wiring to have been stuffed with.
    • Hello, im asking about this guy - coil igniter on rb25det series 1 r33 s1 engine. I need to know if pins on coil side indicate coils itself from 1-6 or it’s firing order so pin nr1 goes to 1st fired spark plug:(1pin-1firing spark, 2pin-5order firing spark, 3-3, 4-6, 5-2, 6-4…)   photo: https://files.fm/f/k9pdug38uq
    • Remove it. Certainly from the hub face. I'm not in love with leaving it on the wheel assembly surface either - but if it is common to do so, then....maybe fair enough. It's not difficult. Just time consuming. For the hub face you just need a large enough block and suitable grades of abrasive paper to get it off flat. The same would be true of the assembly face. Just more time consuming, probably needing a lot more care. It's defo going to be easier just to assemble the wheels as is, seal them up, and check them periodically to see if there's any movement or loosening of the fasteners, than it will be to remove it though.
    • Hello, I got my wheels powder coated and they've powder coated bloody everything the mating surface and hub (even told them not to lol) anyway should I leave it or remove it. (Would be very hard) I've searched a lot and lots of powder coaters don't mask the mating surface but do mask the hub surface. How bad it powder coat on the mating surface or hub? My question is what should I do?
