Guys........ As someone who monitors the sale of R32 GT-R's quite regularly, I am surprised to see their levels in such low numbers.
Currently at time of posting there are only 25 cars available around Australia on Carsales/Carpoint.
This includes all variants of the model (ADM's, N1's, Nismo, V-Spec 1 & 2's).
http://www.carpoint.com.au/all-cars/results.aspx?YearFromShort=1635&SearchAction=N&q=((((((Make%3d%5bNissan%5d%7b%26%7d(Model%3d%5bSkyline%5d%7b%26%7dBadge%3d%5bGT-R%5d))%7b%7c%7d(Make%3d%5bNissan%5d%7b%26%7d(Model%3d%5bSkyline%5d%7b%26%7dBadge%3d%5bGT-R+V-Spec%5d)))%7b%7c%7d(Make%3d%5bNissan%5d%7b%26%7d(Model%3d%5bSkyline%5d%7b%26%7dBadge%3d%5bGT-R+V-Spec+II%5d)))%26(((SiloType%3d%5bDealer+used+cars%5d%7cSiloType%3d%5bBrand+new+cars+in+stock%5d)%7cSiloType%3d%5bDemo+and+near+new+cars%5d)%7cSiloType%3d%5bPrivate+seller+cars%5d))%26Service%3d%5bCarsales%5d)%26Year%3drange%5b1980..1994%5d)&YearToShort=1665&sortby=Price
Only 4 cars are under $20,000 and one of those is $19,990.00.
On the other end, 10 cars are over $30,000.00.
To put things into perspective, on January 1 2012, there were 66. On January 1 this year there were 40.
The numbers consistently hovered around that level through 2013/14.
I also monitor the Japanese Auctions. Over 50% of the cars on offer are rated R. You get the occasional 3.5 very few 4's let alone anything above that.
I suspect we as Australians (private buyers and dealers) have little interest in bringing in cars rated 3 or lower.
As the Americans are now cranking up their demand buying anything in Japan built in 1989 and 1990 I can only see these numbers diminishing further.
I'd be keen on hearing from anyone looking for a car and there experience in finding one at the moment that meets their expectation.
Cheers,
Bob.
- Cause it's an older car, buyers want the best condition they can find.
- And with R Rated GTR's you have to question about it being road registered in AUS...
- I'd say so, their demands would be high cause they have waited so long before the R32's are road legal over there.
Check on gum tree, plenty of them on there and being sold for peanuts. I inspected 2 for people less then 6 months ago and they purchased them for 14k each!! One was an absolute gem of a car, the other was good but not great
There certainly are a lot of R32s being brought into the US now so I'm not surprised availability in Japan is getting scarcer. Pent-up demand was high no doubt because of the long wait and the Gran Turismo/Fast and the Furious crowd is hitting a time where they can afford these cars as well. In the four trips I made to my importer they pretty much sold another R32 to someone each time I was there. They had sold about 10 Nismos alone - no idea how many of the more common versions they must have sold. I know a guy who just privately imported a Nismo and a regular GT-R and sold them immediately. One of the writers on Jalopnik just got one himself so from all indications a staggering number of R32s are making their way Stateside.
That's also because carsales is failing for anything that isn't a new camry.
All the skylines are on gumtree now.
Most cars on gumtree are utter dirtboxes, if the owner can't even shell out $50 for an advert then what else haven't they shelled out for
  • Like 2
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
