The following parts came off my R34 GTR V-Spec, and all prices are slightly negotiable. Lowballers will be ignored
1. Stock R34 GTR Tail lights - $150
2. 2x Lambda o2 sensors for R34 GTR, Used but still in good condition and works. - $80
3. OEM Twin Turbo pipe - $50
4. Xforce R34 GTR dump pipes, used but in VGC, jsut needs a polish and will come out brand new - $250
5. Unknown brand RB26 Camgears - $100
6. 2x HKS Mushroom filters, Used (does not come with the pipe attached to the pod filters) - $60
7. Unknown brand front brake pads (Came off my R34 GTR Brembos), still have plenty of meat left, only changed because a good deal came up on Pmu pads. - $120
8. R34 GTR Cusco Brake Stopper - SOLD
9. Tomei Type B poncams 270 degrees 9.15 lift (these were made in limited quantities, they are not listed on the tomei website but they are 100% genuine, someone on SAU has contacted Tomei regarding it and confirmed they were a limited run.(http://www.sau.com.au/forums/topic/219857-building-an-rb26-for-response/?p=7205516), only reason i'am replacing them is they don't suit my setup needs so i have downsized to Type A poncams, these have done less than 10,000kms and are currently on the car due to be removed on the 20th of this month, if you are interested in this item i'm willing to take a small deposit and put the item on hold for you) - $600
10. Garrett -5 turbos with actuators (coming off car on 20th May, have done around 15,000kms, not sure of condition but still works fine on the car, and open to inspect them, willing to take deposit to hold onto them for you) - $1300
11. Nismo Horn Button - Used but in VGC condition - SOLD
12. OEM R34 GTR V-Spec Stock Suspension - used but no leaks - $80
13. 2x NISMO AFM's (Used, was sold to me broken by a SAU member, plugged it in and came up with no voltage when tuned, all mounting tabs are still intact and in perfect condition, could be a easy fix with soldering inside, but don't know, dont want it sitting around so might as well try sell them) - $100 (Pending pickup)
Contact me on 04228844 eight three
Located in Warrick Farm NSW
Pickup preferred but will post at buyers expense
Cash or bank transfer only, no Paypal.
11149274_10206558061568522_323737469316111139986_10206558060368492_169325912358311101066_10206558061528521_550729119287010404285_10206558060928506_342373831766811052481_10206558061048509_113754458046311262408_10206558060648499_582239255491913392_10206558060688500_110958939818711321883_10206558061488520_446096298424582411223958_10206558099729476_8997095647693
https://www.sau.com.au/forums/topic/456580-assorted-rb26-parts/
UPDATE #1
1. Stock R34 GTR Tail lights - $100
4. Xforce R34 GTR dump pipes, used but in VGC, jsut needs a polish and will come out brand new - $200
5. Unknown brand RB26 Camgears - $80
6. 2x HKS Mushroom filters, Used (does not come with the pipe attached to the pod filters) - $50
7. Unknown brand front brake pads (Came off my R34 GTR Brembos), still have plenty of meat left, only changed because a good deal came up on Pmu pads. - $100
9. Tomei Type B poncams 270 degrees 9.15 lift (these were made in limited quantities, they are not listed on the tomei website but they are 100% genuine, someone on SAU has contacted Tomei regarding it and confirmed they were a limited run.(http://www.sau.com.a...onse/?p=7205516), only reason i'am replacing them is they don't suit my setup needs so i have downsized to Type A poncams, these have done less than 10,000kms and are currently on the car due to be removed on the 20th of this month, if you are interested in this item i'm willing to take a small deposit and put the item on hold for you) - $600 (PENDING DEPOSIT)
13. 2x NISMO AFM's - SOLD
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
