Hi there,
This maybe my first post, so please help me out here.
I recently acquired a 1996 Nissan Skyline R33 GTS 4 door that HAS NOT run for 3 1/2 years.
I have drained the fuel tank, changed the fuel and air cleaner elements.
A new battery has also been installed.
It cranked up and fired into life after a little coaxing. It ran for a few minutes and then I switched it off and changed the oil and oil filter.
Now the engine will not fire up again.
Since changing the fuel filter and air filter, the fuel no longer flows!
There is NO clicking of any relays and NO noise from the pump.
I have checked under the bonnet fuse box and FUEL PUMP fuse is serviceable.
The fuse box under the dash has ALL serviceable fuses.
Problem is, it is all in JAPANESE!
The Google search did not help for the translation as the detailed page dose not match up with the Amp rating or layout of IGN, ACC or BATT.
My main questions are:
1/. The relays are quoted to be inside the boot between the tail lamps under the boot catch assy
They are not there!
Where would they be?
2/. Is there any wiring mods that I can do simply that will get the pump running?
3/. As per Q2, can I put in a HOT wire and run the pump via a relay I supply and trigger it from existing switching wire>
I would like to see this car up and running tomorrow if I can find some quick and easy to do solutions.
Many thanks in advance..
Edited by PranK
Changing 'R32' to 'R33'
https://www.sau.com.au/forums/topic/456597-r33-barn-find/
I just bought a "barn find" r34 and it had the same problem - turned out to be a dud connection on the positive battery terminal. Was cranking fine with a new battery, had all the ignition lights, just not enough current for the fuel pump
https://www.sau.com.au/forums/topic/456597-r33-barn-find/#findComment-7533348
Is said barn red?
Seriously though, start from one end of the system and work through. Power to ecu, power to trigger wire, power to pump relays, which should be under the parcel shelf, next to the battery IIRC, power to tank lid connection etc. (I'm pretty certain i got that order right... been fighting the flu for the past 24 hours and the brain is a bit foggy)
If all is dandy, pump itself may be rooted. Sitting in stale fuel for 3+ years will clog it up with varnish pretty fast. Did you clean the tank out or just drain it? Prick of a job to do in a 33
I thought My bosch 040 had died a while ago, and after replacing the pump, it actually turned out to be the pump trigger wire burnt out from another unrelated issue.
As per Q2 and 3, you can do both, but both won't work if there's another wiring issue, or the pumps is rooted, unless you simply hardwire from the battery to the tank lid connection.
Hope that helps you in any way.
https://www.sau.com.au/forums/topic/456597-r33-barn-find/#findComment-7533911
Hi
Still have NO POWER to pump.
Checked all fuses and swapped relays.
ZILCH
Connected 12volts direct to pump and turned key YOU BEAUTY! .....................IT RUNS!
Will now trace and find the break.
If not, should I supply 12volts from battery direct to a relay AND switch it from ignition side of fuse box??
https://www.sau.com.au/forums/topic/456597-r33-barn-find/#findComment-7538470
Could be a few thing but the three most obvious to me are 1) the fuel pump control module which povides the amperage to the pump which is control with the signal from the ECU, 2) the fuel pump relay on the back wall of the truck, 3) the alarm which should be spliced into the fuel control signal from the ECU to cut that signal so the pump doesn't activate
https://www.sau.com.au/forums/topic/456597-r33-barn-find/#findComment-7538661
I just went through this on another car. My problem turned out to be a bad ground wire AND a faulty pump! Sometimes the ground was there, sometimes it wasn't. Sometimes the pump ran, sometimes it didn't (internal fault in pump) Check the ground wiring and bang on the fuel tank, doing so might make the pump run, which if it does you know the pump is faulty.
https://www.sau.com.au/forums/topic/456597-r33-barn-find/#findComment-7539205
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
