Greetings,
I am debating going with the OS giken 5 speed gearset + input shaft for my BC stroker + 8374 EFR R32 GTR build and I'm curious what other parts I'd need besides the gearset, input shaft, and center plate for the rebuild. Basically I'm looking for a part numbers or a place to purchase the synchro sets and bearings for transmission overhaul. I'm in the USA and finding parts and information is tough here.
I already have the twin coppermix clutch kit, new throwout bearing, and trans mounts.
Thank You,
Patrick
Edited by HarrisRacing
RHD Japan or Perfect Run, amongst other places that deliver directly from Japan probably your best option.
They will have what you want or can get it at a price probably cheaper than you'll get from the USA or AUS.
Only problem is you usually have to wait several months for an item like that.
Great advice so far...but which EXACT parts am I looking for?
And yes I have ordered most of my stuff from RHDjapan so far. EXCELLENT prices and service if you can stand a slight wait (especially on OEM parts).
Ffs. If my laptop didn't die, I had all the parts listed for the OS 5 speed conversion.
Basically what you need is all the Series 3 synchro's, balk rings and whatever else. If you dig around hard enough on the forum, I'm sure I've posted it up.
are these parts a bitch to fit and/or find ?
32604 - 30P60 Ring Baulk 1
32604 - 30P61 Ring Baulk 1
32604 - 40P61 Ring Baulk 1
32606 - 30P10 Sleeve-CPRG, 5th 1
32611 - AA510 Sleeve-CPRG, 5th 1
32605 - 310P11 Hub Synchro 1
32811 - 05U10 Fork shift 1
32609 - 70L15 Insert shifting 3
32603 30P00 Spring shifting 2
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
