Hi all
I'm wanting some expertise advice on what size exhaust I should be running for the expected power output of my fresh engine
Car is R33 GTR
Forged RB26
Ported head
HKS 272 deg cams
2860-5 turbos
Walbro 460 intank pump
1250cc injectors
Power FC
Xforce dumps
Into 2.5 front pipe that goes to 3 inch
Into 3.5 inch decat
Then 3.5 inch tomei Ti expreme titanium catback system
Hoping for around 600hp at the treads.
Would this exhaust system flow enough ?
On another note
I hate the sound of my exhaust while moving. Sounds great on idle but the moment the foot goes down it sound like a dirty Na VL with no exhaust. Will adding a high flow cat help ?
Thanks in advance
https://www.sau.com.au/forums/topic/456600-what-exhaust-size-for-what-power/
Only thing i will say is lose the X force dumps, these are a direct copy of the HKS ones are they are only an improvment over stock R32 dump pipes, get some thing with 3" outlets and then a front pipe with 3" inlets and 3.5" outlet to match the decat
its your mufflers and resonators that change/reduce the sound mostly. Though for sure a cat convertor will also help certain types of sounds too.
Sounds like your issue is more around the muffler and resonator side of things though.
With front being stainless or to small ?
as Xklaba said
If you plan on staying with low mount twins go out and get a good exhaust. CES do a good dump and from there go a good cat and muffler and 4". Do it once and do it right.
This, i have both types of CES dump pipes, factory type on my R32 with matching CES front pipe and comp series dumps on my R34 with custom twin 3" into single 4"
CES have the best split type dump pipes on the market and IMO the comp series are better then bellmouth type pump pipes
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
