Hi all
I'm wanting some expertise advice on what size exhaust I should be running for the expected power output of my fresh engine
Car is R33 GTR
Forged RB26
Ported head
HKS 272 deg cams
2860-5 turbos
Walbro 460 intank pump
1250cc injectors
Power FC
Xforce dumps
Into 2.5 front pipe that goes to 3 inch
Into 3.5 inch decat
Then 3.5 inch tomei Ti expreme titanium catback system
Hoping for around 600hp at the treads.
Would this exhaust system flow enough ?
On another note
I hate the sound of my exhaust while moving. Sounds great on idle but the moment the foot goes down it sound like a dirty Na VL with no exhaust. Will adding a high flow cat help ?
Thanks in advance
https://www.sau.com.au/forums/topic/456600-what-exhaust-size-for-what-power/
Only thing i will say is lose the X force dumps, these are a direct copy of the HKS ones are they are only an improvment over stock R32 dump pipes, get some thing with 3" outlets and then a front pipe with 3" inlets and 3.5" outlet to match the decat
its your mufflers and resonators that change/reduce the sound mostly. Though for sure a cat convertor will also help certain types of sounds too.
Sounds like your issue is more around the muffler and resonator side of things though.
With front being stainless or to small ?
as Xklaba said
If you plan on staying with low mount twins go out and get a good exhaust. CES do a good dump and from there go a good cat and muffler and 4". Do it once and do it right.
This, i have both types of CES dump pipes, factory type on my R32 with matching CES front pipe and comp series dumps on my R34 with custom twin 3" into single 4"
CES have the best split type dump pipes on the market and IMO the comp series are better then bellmouth type pump pipes
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
