  • 1 month later...
Engine covers sold, mine never had a coil cover and i can have a look at the heat sheild but i think it got bent n twisted removing it sorry mate
Hey guys,
Clearing out heaps of bits from my recent build.
Have pretty much all the interior.
- Dash
- Cluster
- Tripple gauges with boost, oil temp and voltage also have the boost sensor it still works
- Front seats
- Back seats
- Trim panels
- Interior loom
- Hood lining
- Carpets
- Glovebox
- Interior lights
- Steering surround
- Indicator/ Wiper stalk
- Ignition Barrel (can also sell with boot latch, door latches etc so can have all matching Keys)
- Seatbelts
- AC box and fan etc..
Possibly more i have just forgotten alot
Engine Bay
- Full 3" system with high flow 100cell cat
- Stock intake manifold
- Stock Highly polished inlet manifold
- ABS pump
- ABS module
- Hicas Computer
- TCS Computer
- TB with TCS
- Oil heater assembly
- stock good cond Radiator
- fan and viscous coupling
- billet HKS style top feed injector rail
Once again heaps more just ask what you want
All located in SA but can post if needed. Dont really know prices but shoot me reasonable offers and its probs all yours
Updated abit but still shoot me with what your chasing
  • 2 months later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
