Yep, about to jump on the Jerky wagon!
The Cube is a cool car, basically the same engine and drivetrain as the Micra so parts and stuff are easy to get locally. They look funky, have lots of room and you can buy a bolt on supercharger kit! Perfect city daily.
  • Like 2
Brilliant , that's what I want bigger space inside and perfect for daily use , I have Honda Civic ( Sedan ) as my daily car now but not big enough for what i want to do with it. Thanks Lachy X [emoji509][emoji517][emoji508]
And bonus, it's not a Honda! :woot:
  • Like 2
Don't buy outdoor furnitures from segals [emoji90][emoji35] Cheap furnitures with bad customer service ! Paid for delivery but they refused to bring the goods inside the house , instead leave them all the big boxes outside the house for me to bring it in ? What am I paying the extra $80 for ??????? post-139458-14579294621784_thumb.jpg
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
