Morning all. I'll never be able to clean the seats in this weather...
Car seats ? I know someone who can clean the car seats for you - if you bring the car to him it's $30 & $50 if he goes to you - he use proper machine injections / extractions for car seats
Hai Dale, been awhile, hows it been? :action-smiley-069:
Hey Col, it has been a while!
Its been generally busier than a one legged man in an arse kicking competition :(
Plus, I have a dirt bike now, so even less time in front of a screen
Im pretty good at cleaning cars(not an expert) . Rain let up so I removed the passenger seat and floormats. Shampoo'd them Al. Filled my little dysons tank twice on the floor matt's alone. Drying the seat now and then I'll put it back in the car.
  • Like 1
Cool , too easy but just in case if you're stuck and have no time to clean just give me a shout
  • Like 1
Hahahahahaha yea wet dog smell it's hard to get rid off , but hey try using powdered baking soda and powdered charcoal to help to remove unpleasant smells from your car, You'll find that cleanup is easier when using both dry baking soda and charcoal since you can vacuum it up.
Its mostly gone which is good. On Wednesday I'll remove the rear seat and clean that up, then it's onto the carpet in the car. On the mechanical side I'm hoping to Jack the car up this week and begin investigating and A friend of mine is going to try make it up on Thursday to fix my tachometers. Progress..
  • Like 1
Awesome, I guess you know what you're doing so all
The best & Good luck Manne.
Crap day was crap. Someone got fingers caught in a press. Not pretty...
Not cool, back in nz had a mate who got his hand caught in a huge newspaper printing press. Had to take machine apart to get his hand out normally a 1.5-2 hr job was done in 15-20 mins. He lost 2 fingers, atleast we now have a nickname for him now we call him fingers. Anyway hope they are ok?
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
