Good plan right there. 25's respond to minimal mods half the time, quality high mount/manifold/gate/exhaust/injectors/ECU. Got one down here putting out 600hp with standards internals bar head gasket and cams
Ever heard of Evanco Mechanical?
My End Goal is 500hp. I don't want/need more than that. (We always say that right?), but that is a long term goal.
I forgot to mention the car has a ridiculous exhaust system (can fit my foot inside the tip ;) )
Oh, here is a photo of the freshly washed R33 4 Door, nearly ready to get some plates slapped onto her. (not embedding because the photo is huge)
Theres so much bird poo burn on her, as well as weird stains that I just couldn't remove and some weird blue-tacky glue stuff that's somehow leaked onto her. My current tools were not able to remove those.
Restorefx in Bibra lake does some pretty awesome work on car paint. Check them out. Edited by colin.ssc
I already have a motor that makes a lazy 510hp, wanna buy it off me?
  • Like 1
*WRECKING* new stock, sr20det 180sx
Mandurah, Western Australia
New stock in.
Sr20det, manual, runs and drives, video of engine running/starting is available, comp test will be performed tomorow, and 180sx will be dismantled as of tomorow.
*Notes*
Coilovers seam unservicable/seized, JIC fully adjustable fronts, rears are GAB shocks and springs, non height adjustable, with adjustable dampers.
Has good clutch, think extreme of some description. Nice feel and grab on operation.
5 speed box is good. No crunches or grinds. Smooth operation.
Engine runs/starts fine. No excessive blow by or smoke. Looks to have T25 garette.
Has VLSD and drift pineapples on the subframe.
Greddy turbo timer, blitz BOV.
has majority of rear plastics and carpet side trims, dash mat ect, steering wheel in decent condition if anyones chasing stock gear.
Only 3 rims as one is egged, 17x7 lenso.
Engine (depending on comp) complete $1200
Sr20det wiring loom $100
Turbo manual ecu $100
5 speed box $300
Clutch $200
Very fkn tempting
  • Like 1
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
