they said they're going to need another day with the car, I asked then if they could give me a progress report on the car, and they told me They've Replaced the Tint on the Rear window, and replace the springs in the front (it was too low at the front). I'm not an expert and I have no idea how busy these guys are, but they've had the car since Midday Tuesday and all they've done is put a layer of tint on the rear window and swap the springs. They told me they are currently working on the tachometer now, but the car won't be ready until end of day tomorrow.
Doesn't look like I'm bringing it to the cruise.
Hi do you guys know what process is to register a interstate vehicle in WA, have any of you done it ? Is it hard ?
I did search registering interstate but only found eastern state stuff.
Think you need to go pits , and get a road worthy Certificate , haven't done it my self tho [emoji28]
  • Like 1
Sad. They get pretty busy most days with engine rebuilds, mods and usual services. But pretty annoying they promised two days but took longer.
Being in similar environment, everyone wants to know when it will be ready
Go short and your a flaming mongrel if it blows out.
Go long and you miss out
Best guess is still only a guess
Right, Under promise, Over Deliver, retail 101.
I'm not upset that it's taking a bit longer, I'm disappointed because we discussed a time-frame, and they couldn't keep it, and they didn't ring me to tell me it was going to take longer.
Also, it took more than 24hours, just to apply tint to 1 window, I know they out-source the tint... but it doesn't take 24 hours to tint 1 window.
also, they charge by the hour, so the longer they take, the more I pay.
Ring around on places that tint c what the going rate is this way you know you wont be over charged, also you are paying for something to be done/service if you dont get said service then negotiate
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
