I talked them down to the original quote. The reason it was so high was because the door kyp supplied was in really bad condition (according to uneeda) he documented the repairs (as per my request, I said anything you charge me for I want to see a photo of). He claims that they spent 5 days panel beating the door just to get it to fit. The Respray is good. The colour match is perfect. Will I go back? No. The job might be good but their work ethic is crap. They should have called me and told me about all of these issues and let me decide if I wanted them to keep working on it or not. Plus they went 5 weeks over-time.
Yeah well the Original Quote was 1 Week if they could find a door. It took them 3 weeks to find a door, which I ended up finding for them, and then two weeks to get the door on the car. Now seeing how banged up the door was when they picked it up (almost looked like a different door), it makes sense... but oh well.
The way I see it is, the car is back in my hands, and fixed. Now I need to save some money, and once i'm back in my 'green' zone, I will continue to work on it.
Morning. So, now that i have my car back. I'm going to clay, cut and polish it. Starting with the hood and seeing how I go. This is really an experiment to see what results I get. The hood is covered in bird poo burn and numerous other stains, so... Let's get started
Wish I only had to wash mine... Gotz to do a service :(
Also gotta service our suzuki :(
nah. Those are rock chips. I probably removed the stains by 50% and on the right angles they're not noticeable. But they're still there.
I should mention the process I used was (in this order).
 Wash --> Clay --> Cut --> Polish --> Wax, and then I sprayed some Maguires "quick detailer" on top.
It took roughly one hour, just on the Hood alone.
Edited by Manne
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
