I talked them down to the original quote. The reason it was so high was because the door kyp supplied was in really bad condition (according to uneeda) he documented the repairs (as per my request, I said anything you charge me for I want to see a photo of). He claims that they spent 5 days panel beating the door just to get it to fit. The Respray is good. The colour match is perfect. Will I go back? No. The job might be good but their work ethic is crap. They should have called me and told me about all of these issues and let me decide if I wanted them to keep working on it or not. Plus they went 5 weeks over-time.
Yeah well the Original Quote was 1 Week if they could find a door. It took them 3 weeks to find a door, which I ended up finding for them, and then two weeks to get the door on the car. Now seeing how banged up the door was when they picked it up (almost looked like a different door), it makes sense... but oh well.
The way I see it is, the car is back in my hands, and fixed. Now I need to save some money, and once i'm back in my 'green' zone, I will continue to work on it.
Morning. So, now that i have my car back. I'm going to clay, cut and polish it. Starting with the hood and seeing how I go. This is really an experiment to see what results I get. The hood is covered in bird poo burn and numerous other stains, so... Let's get started
Wish I only had to wash mine... Gotz to do a service :(
Also gotta service our suzuki :(
nah. Those are rock chips. I probably removed the stains by 50% and on the right angles they're not noticeable. But they're still there.
I should mention the process I used was (in this order).
 Wash --> Clay --> Cut --> Polish --> Wax, and then I sprayed some Maguires "quick detailer" on top.
It took roughly one hour, just on the Hood alone.
Edited by Manne
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
