my Garage houses my Motorcycle and other Car, and because I already Started, the Skyline isn't running at the moment, and I can't move everything out to push it in.
As for tomorrow night, my Wife, my Eldest Brother and his Partner are going to the movies together, and I wanted to pick them up in my Skyline.
So instead of fixing my car, I am sitting here, watching James May the Reassembler.
Edited by Manne
31 minutes ago, t_revz said:
Pressure musta dropped hey?
Yea the last tune was done with the dodgy fuel pump. Now with the new one certain rev points it surges harder. And I don't think they tuned it that well either.
19 minutes ago, Manne said:
I can't recommend C-Red enough for that. Mark is amazing.
No thanks, I never had a very good impression or experience with them. Dealt with them multiple occasions and years. Not gonna go back. But if they are treating you well, by all means use them!
I honestly couldn't imagine a bad experience with them. They've been really good to me, always willing to listen, and offer advice/little tricks to make things easier. Whenever I've had issues Diagnosing them has been free and their pricing always reasonable.
Hell, they let me borrow a clamp once to remove my seized oil filter.
Z00key uses them too.
  • Like 1
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
