5 minutes ago, z00key said:
Guessing but would say about 5.45 to 6. Car meets are the few things that motivate me to be early as I always want a good parking spot.
True, I haven't been on one in quite a few years. Finger crossed I get my car back today
So, Martin, Z00key and I are probably going to meet at Carousel around 5:45ish.
Did you want to meet us there, or should we come to you and then jump on Graham Farmer?
After that, We're heading up to Hillary's boat harbor carpark, to meet with Ellie and have a small meet n greet.
Then we're heading to Westfields Whitfords to the larger meet, chill out there, look at cars etc...
Sound good?
Is anyone else coming along? Let us know to minimize confusion.
Ps: all clean.
  • Like 2
29 minutes ago, Manne said:
This is the FB pages BTW. 100 people confirmed 500 maybes.
Look forward to hearing how many yellows get handed out - how many muppets    prang it - and all the stories of muppet behaviour ????
  • Like 2
Sound good?
Ps: all clean.
Sounds like a good plan ! [emoji41][emoji818]️[emoji1591]
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
