1 minute ago, z00key said:
Ha yeah he told me will cost him around the 12 - 15k for the work i was like can buy a skyline for that. Cheers anyway
I honestly have no idea why you would, like it's a fkn Pajero mate, what's the point? Not even a Pajero Evo.
Just tell him to buy a SWB Pootrol, RB25DET NEO swap and then this -
  • Like 1
1 hour ago, turboedsloth said:
hot dang. makes me want a pootrol
But do you really? :P
Chuckie is a bit dark at me because I'm not coming down this weekend.
BTW Corey, we returned the pads we didn't need, lemme know what I owe you for the other Wagner pads and I'll credit your account if that's cool with you? Otherwise I have cc details for ya :)
You got me, i don't want one
He's dark on me aswell for being so busy and not being able to help him. Oh well
Consider the pads a sponsorship to the cause, you did the R & D and turns out i'll steer clear of them :down:
  • Like 1
Oh well :P
Haha, thanks man, much appreciated. Bendix Ultimates held up the best but if you ever have the choice of Bendix CT or Wagners, get the CTs (they were our 3rd set of pads).
Bloke at Bunbury Auto One was shocked when I told him they lasted about a morning lol.
  • Like 1
3 minutes ago, turboedsloth said:
I went in there sunday morning to get some oil and asked about them. They reckon they are dba's mid range pad, i try and use ct's from veales when i need them
There are some pictures of the worn pads, I'll post them in here when I found them, but we gave it hell.
Lost 1L of oil on Saturday and about 1.5L on Sunday. RHF tyre is fkd, bald on the edge already hahaha!
I've seen a few skylines out today, Maroon R33 gtst at the lights Hale x Welshpool, White R32 turning off Albany HWY onto Nicholson road, Silver R33 travelling southbound on Orrong Road.  Midnight Purple GTR turning off Orrong onto Leech HWY.
Three of these had female drivers.:1310_thumbsup_tone1:
  • Like 3
Nice, did you show them your penis?
  • Like 4
Girls powahhhhhhhh [emoji1320]
  • Like 1
http://carsales.mobi/cars/details/_/SSE-AD-4226380?WT.seg_4=AutoAlert;PCAA
[emoji25] [emoji26] [emoji27] how does that work it sold in 12hrs i check my email 12hr too late im crying inside.
Oh what a nice ride
  • Like 2
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
