  On 19/10/2016 at 4:08 AM, colin.ssc said:
Yeah English schools seem to be a good go over there. Have/had a few friends who were there for some years teaching English.
An excuse to go visit Japan then [emoji14]
Was ok money I guess. The missus worked from home but had to give 50% of income to the company providing the curriculum.
My company we made up most of the lessons based on things we heard them talk about. So I'm sure between us we could make lessons, and I think a native English speaker and a japanese teacher with 8 years in Australia could be popular.
The worst part is we just built our dream home :(
The worst part is we just built our dream home [emoji20]
Leave it as an investment place here. Come back n kick tenants out and have it back haha
  On 19/10/2016 at 4:53 AM, z00key said:
Oh and started watching the inital d movie finally trev the one with that guy from american pie in it from 2004 i think it is quite good took a while to find a good copy. Also watched a movie called nerve also good
Animation series is better than the movie, but still an ok movie
American pie actor? Don't remember...
@Elleali76 there is a 1 day sale on tomorrow at jb on a samsung 65" series 7 tv if you are interested $1000 off unsure if can get cheaper but if u r keen will look into it further? It was a good deal so thought would put it out there.
  • Like 2
Oh yes please Dean [emoji7]
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
