Evening all!.
Met a professional detailer today, asked him about his cleaning methods etc... was a fun chat, but was interesting to see how out-of-date some of these guys are with modern cleaning methods, he took my details and told me he'd call me if he needed an extra hand.
Other than that pretty average crappy day at work.
  • Like 1
Hey all, been so busy havent had time to look at this T_T
Hows everyone going?
Tried to buy the Nintendo Classic but failed the first time, and today JB and EB Games have pre-orders.....failed again :(
  • Like 1
Yea I heard. I know first round I missed out since I went to the websites late. Today on the other hand.......JB was sold out in 90 seconds and EB website crashed.
Oh wells.....maybe I'll get lucky tomorrow since EB is doing pre-orders again.
  • Like 1
Such a geek!!
Wish I had the time :(
  • Like 1
Morning all.
Took yesterday off and spent it digging up my front garden. Sneezing black dust boogers out nowdefault_bunny.gif
That's me everytime I use the bobcat
WAIT...... You took a day off??? You feeling ok?
Have only been talking about doing it for a year, so i got stuck into it. Wifey even got some dirt on her
  • Like 2
On 11/11/2016 at 11:02 PM, Manne said:
I think its gorgeous, and has some impressive engineering.
would I pay $400,000 for one? No.
This, will be an amazing car but compared to what Japan and the USA pay for one, no thanks.
  • Like 2
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
