Issue I had with adoption agencies is that I never had a pet before and so they weren't too keen on giving me one.
HRWA are not like that, they just want to ensure you know what you are getting into, Huskys are a unique breed and are extremely active
Malamutes are just huskies on steroids.  all my animals are sleeping because they live happy relaxing lifestyles. my dog gets two 8km walks a day.
Oh, and yeah, adopt one. there's so many out there.
Edited by Manne
  • Like 1
Yea ok I'll have a look. House doesn't have an alfresco area. Ideally I'm hoping to get that up at least for work out door shade area for the dog.
Have a chat with Anne, as long as you know what your getting into you will be fine, they charge $400 for costs of desexing, microchips and worming etc
http://www.huskyrescue.com.au
Tell her I sent you 0413 770 092
  • Like 1
I don't have a very large house, in fact it is quite small. To make up for this, I take my dog for long walks and play with him at the park, which is perfectly fine. We'll play tug of war in the yard and sometimes we wrestle, he's 55kg...decent opponent.
  • Like 1
No wonder your knees are shot 16km per day plus walking around at work [emoji15][emoji15]
  • Like 1
35 minutes ago, shoey85 said:
No wonder your knees are shot 16km per day plus walking around at work emoji15.pngemoji15.png
So about that, I have some sort of Chondral Fissuring of both knees. Essentially, the Cartilage for both knees has deep cracks and fissures through it, some of it has also started peeling off of the bone, and there a small, loose bits of cartilage floating around the knee too.
Theres no surgical options, supposedly (Rheumatologist tells me that, so does my GP and Physio), so the best Cure is to Grind back the Cartilage with low-impact leg exercises.
I had to buy a particular Exercise bike, that has a heavy flywheel (7kg), set the resistance up, so it's like pushing a weight, a slowly do that for 30 minutes a day. This not only builds muscle, but grinds back all my broken cartilage, and hopefully creates a new groove for my knee caps to sit in. Unfortunately it's a long, slow, painful process, slowly improving every week.
Option B is to take Anti inflammatory pills for the rest of my life, with monthly (expensive) Steroid Injections and fillers (with the risk of infection from each one).
Fux man that's really not good, hope
You do get better sooner rather than later!
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
