Fair enough, I thought as much too.
Can't wait to see and hear how it turns out.
All I can say is WOW!! It turned out to be amazing! Better than I had hoped [emoji106]?[emoji106]?[emoji106]?[emoji16][emoji16][emoji16][emoji344][emoji344][emoji444][emoji445]
  • Like 2
35 minutes ago, z00key said:
Never heard of it? Or nother name 4 crabs?
Pretty sure its Sunburn.
Just now, shoey85 said:
All I can say is WOW!! It turned out to be amazing! Better than I had hoped emoji106.png?emoji106.png?emoji106.png?emoji16.pngemoji16.pngemoji16.pngemoji344.pngemoji344.pngemoji444.pngemoji445.png
This makes me happy.
  • Like 2
I'd happily swap for crabs
When it hits I feel like clawing the skin off my back with a blunt nail. I'm sure sleeping on a fire ant nest would be more relaxing
  • Like 1
What did you get?
What did you get?
New sound system for the R34, JL sub and front splits, R type coaxial for the back, new deck alpine and got some amps from a mate who helped install it all. Sounds mint, quite loud too with a decent rumble [emoji16]
  • Like 1
Rain isn't that bad if you wash ya car outside use the rain as a final rinse after the hose it then garage it n dry it there [emoji2]
You gota remember scheme water has that much calcium and hard minerals in it thats why you get all them white dry dots. [emoji34]
Its like going to the car wash and getting the spot free rinse basically water runs though a water softener. [emoji16]
  • Like 1
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
