Did you get accomodation for the Friday?
Morning All ,
Oh Martin , I wish I had a personal assistant to do my works , been so busy lately , up at silly o'clock in the morning ( 3.30am) to check All site areas , finish at silly o'clock 8 in the evening and by the time I come home knackered and all closed ( sorry for the whining ) It's going to be long day for me today , I'll try to ring them when I can :( x
  • Like 1
1 minute ago, ElleAli76 said:
Are you going Trev ? It's this Saturday - there is few different events
sorry my bad, i didnt see the date. i assumed it was Friday night before racewars and a cruise around Albany
  • Like 1
Yea there is few events pre-meets before the race wars or the car cruising on Friday next week, I can Join this week pre-meet but , def catch up with youse lot at the dinner party Saturday !
Morning All ,
Oh Martin , I wish I had a personal assistant to do my works , been so busy lately , up at silly o'clock in the morning ( 3.30am) to check All site areas , finish at silly o'clock 8 in the evening and by the time I come home knackered and all closed ( sorry for the whining ) It's going to be long day for me today , I'll try to ring them when I can [emoji20] x
You should get a PA then [emoji6]
  • Like 1
oh your going to the dinner party?
i thought you were baby sitting my kids :)
  • Like 1
  • Like 1
Now working the Sunday morning shift at RaceWars, if anyone wants to join me at the 6 Degrees to see the NBL grand final game 3 they're more than welcome.
http://sixdegreeshotelmotel.com.au/
    • It's (the TPS) buzzing? Or something else is buzzing in response? Remove the IACV from the plenum. Block the hole into the plenum with your hand. Get someone to start the car. Let some air is. Do the revs flare up? This is checking that the path into the plenum is clean. After that, is the air hose leading to the IACV fuly clear? After that, either you didn't clean it thoroughly enough to allow the valve to move, or it is broken.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
