If you're actively working as one, I'd love a quote on my skyline.
Unfortunately not any more.
I left many years ago but have painted a few cars at home for family. Last one was shoey87 nissan pulsar sss with a sr20det conversion. One befor that was my dads triumph sprint 1977 full reso running a sr20det. Both where flow coated and came out like glass
  • Like 1
Fair enough :96_ok_hand:
Any pics of the triumph?
  • Like 1
On 3/27/2017 at 1:22 PM, pol1on1 said:
Garrett 2860-5 turbos
Trust hard intake pipe kit
HKS dump pipes
HKS front pipe
Hi –Flow cat (Venom)
Tomei Ti Extreme – 3.5” titanium cat back 110mm intercooler.
Very flowing now got to save up and do my head port polish n 1mm oversize that would be my dream and cams n lots of stuff thats out of reach haha emoji12.png
1mm oversize i doubt would be required unless aiming north of 800hp. bigger ports n valves means more flow but the airspeed slows down and sometimes wont mix as well. bigger isnt always better. i would definetely research more before going down that path.
HeadTorque in Ossie park did port n polish and modified the chambers on mine. they were great to deal with
  • Like 1
On 3/27/2017 at 7:22 PM, pol1on1 said:
I got 19psi on stock internals 412hp just slaps some sticky slicks on and say bye bye to the lumpy v8 that thinks his cool!
Haha
you must have a heap left in it. -5's are good for around 400KW at the wheels IIRC
  • Like 1
so i setup the Water/Meth on my Rodeo before going away Monday,
holy fark it makes some powah now!!! as soon as the pump kicks it, boost jumps up about 4psi and it pulls like a train. Id say it makes 30-40% more powah now. i just hope it doesnt throw a leg outta bed :blink:
  • Like 1
30 will bust it [emoji4]
Pffft
I had more than 42psi and it didn't bust, it just threw raw unburned fuel out the exhaust as it was so rich and timing was so retarded.
It made more than 42 but I don't know how much as that's as far as the map sensor read. Still made 300kw at the wheels while doing it too.
Just now, TiTAN said:
Pffft
did you go full retard?
  • Like 2
naa, it fluctuates when i move the cable at the pyro. Id say cos the engine rocks lots at idle the cable may have failed. i just fitted a new one and it only lasted 2 days. ill email to see if there is warranty
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
