@turboedsloth Hey Corey, off the top of your head do you know the catch can capacity? i filled it in 400km. im going to fit/modify baffles in the rocker cover next week.
PS i need to take you for a drive and show you how much the methanol injection affects my ute :D
Go hard or go home!
U shouldnt need over sized valves, just a port clean, polish and port match.
Anyone on Instagram?
I made near 400kw with nothing but better valve Springs to hold more boost. No porting or cams or valve upgrades, not even port matching, Just extra boost.
394kw @ 26 psi on a 25/30. Gt35r (2007 spec) 6boob manifold, 3.5" exhaust with 2 massive mufflers so it was 90db @ 3500rpm, 4" intake, 3" intercooler piping, 4" Chinese ebay intercooler and a legit greddy intake manifold with q45 TB.
Everyone needs to stop being so girly with their boost levels, turn it up till it stops making power not some silly oh I can't have more than 20 attitude.
Learn to not fear the boost but instead embrace it and make bulk midrange power with all that extra air.
  • Like 2
I couldnt agree more, im the uk we turn it up and see what happens. If it holds 3 bar then it holds. If it blows ic pipes of u have the tools in the glove box to refit and if mr rod and piston make a sharp stage right exit u call a tow lol
Whats the point in paying all that money to go small? I can understand the risk factor, drop all that cash and watch it potentially disapear up in smoke but i guarantee ul have a big old smile on ya face ?
  • Like 1
Whats the point in paying all that money to go small? I can understand the risk factor, drop all that cash and watch it potentially disapear up in smoke but i guarantee ul have a big old smile on ya face [emoji16]
Im guessing no wife lol
  • Like 1
Married for 5 years and about to buy a house lol i just dont see the point in building a motor to hold say 600 hp and then only run it on 350 or 400, u mite aswell build it to that level and save urself the cash
  • Like 1
Reliability coz i want it on max psi setting always so every turn i do i give it to it.
Not a one off thing when i see a falcoon.
Standard gaskets n studs ?
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
