Neat as job on the tubing and lagging. The yellow hoses look cool too. Maybe I should stick to diesels!
Blue for all hoses expect those I could match size or shape and fuel lines
Removed entire wiring harness and wrapped it yellow
Telstra and "Cheap" don't exactly go together, unfortunately.
I've sold phones for nearly a decade now and honestly don't believe in "one phone to rule them all".
Iphone 7's seem pretty decent,  but as always, sept/oct = new iphone.
Add $15 if you want "Stay Connected" which is Telstra protection package for the phone (Replacement phone if anything happens to yours).
https://www.telstra.com.au/mobile-phones/mobiles-on-a-plan/iphone/iphone-7
https://www.telstra.com.au/mobile-phones/mobiles-on-a-plan/iphone/iphone-7-plus
These are the current prices, Other thing to look into would be purchasing the phones Outright, and signing up on a BYO Phone plan.
https://www.telstra.com.au/mobile-phones/plans-and-rates#byo
The benefit of this is that it's much cheaper per month and if something bad were to happen to either phone, you can still upgrade it to a Mobile Phone Plan and get a new phone. The downside is paying upfront for a phone.
That's about all the information I can give you, the rest is you making a decision, and hopefully coming to see me so I can earn that $$ [emoji6]
I'm after a dishwasher too so might kill 2 birds with 1 stone. Missus lost hers 2 days before going to Japan so will be keen to do it ASAP
I'm not "hip" and up with technology when it comes to phones. Currently have iphone 4 and forced my wife to stick with hers too. Haha
Where did u get the washer bottle from? I codged mine in and it looks crap.
Original tank. Soaked in degreaser, used high pressure cleaner to wash it like new. Cap was broken so fitted a CAT blanking cap for the lid. It fits tight
Wow that's tidy. Engineering vs Frankenstein!
Does the rubber at the end of the pod filter run to the standard hole from the air box or down to the front bumper as a cold air intake? Your inspiring me to get in to work and get on with it instead of bring lazy.
Sorry I'm lost...
Pod filter> scotty nm35 intake> hypergear SS2> intercooler
Have had plans to fit CAI through standard holes but with a new house I've been too busy
More than hip with 1990s technology, show us your engine bay!
https://www.jbhifi.com.au/whitegoods-appliances/washing-machines/
Sadly, I know nothing of Washing Machines.
But, if you know what you want I can get that sorted.
That's ok I don't need a washing machine.... A dishwasher will be fine :)
  • Like 2
10 hours ago, t_revz said:
Looking at 2 new iPhones. Would prefer cheapest plans. Currently $50 a month for each of ours.
Which model should we get. Will be telstra
Depends what you want the phone for? iPhone 7 is pretty good but if you want a better camera and love taking photos etc then iPhone 7 Plus will be the way to go. However, bigger screen etc..also, new iPhones should come out in Sept/Oct....the prices for iPhone 7/7+ usually drops then.
I assume you are going with Telstra cause you are down that way and usually go to areas without Optus/Vodafone signals?
Yep only telstra signal at work. I don't need a flash camera. Normal is fine.
Usually we just use them for calls or bit of browsing the net when not home. Not that much really
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
