Thanks for the help dude, you know your shit. :91_thumbsup:
The blue hose has kinked, it's not the correct hose, previous owner must've just slapped it on there.
I'll check out those websites and make a few calls on Monday.
How did you go with finding the s/s wound 5/8" hose today? I wouldn't mind seeing if I could get the original cam breather hose from Nissan also depending on price?
I didn't, I worked all day, won't have a chance to look into it until wednesday
  • Like 1
1 hour ago, Beyond Blue R33 said:
Hicas, attesa, gt-st, gt-r, gt-t, R32, R33, R34, R35, evo, wrx, Nsx, type-r, fc, fd, ae86, asashi, sake, sushi. I'm a bit limited with my Japanese. What about t-revs? Fresh from the land of the rising sun? No substitute for experience!
my wife is a japanese teacher who hasnt worked since having kids, but perth is too far away :(
  • Like 1
2 hours ago, Beyond Blue R33 said:
3 hours ago, t_revz said:
got none...
Ahh, bourbon/whisky, best cure for any cold or flu, till the alarm goes off at 5:30am the next day. Putting a lemon in the neck of the beer should help out alot also.
yes i agree.
im considering putting honey in a bourbon/coke :)
  • Like 1
After 3 months of squealing and telling myself they will bed in. I finally got off my cake hole and chamfered the new front pads. Only the p/s was squealing but I did both to be sure. I took it real easy on them to bed them in and aren't sure why the p/s did and the d/s didn't? Dba slotted rotors and bendix advance pads. Any ideas?
what process did you follow?
i have Q1RM pads. they said to do 2 runs from 60-0 as fast as possible. then 2 runs from 100-0 as fast as possible. i had just skimmed rotors too. never had any noise from them
  • Like 1
is wednesdays your day off?
i have mon-fri off next week. might come visit one day
Ill check out what we have at work tomorrow and see if we have anything like it and let you know. I went with the clear s/s wound so it wouldn't collapse and could see if it was leaving any oil residue or staining inside the tube after the s/s wool packed catch can. Before the air intake to the turbo. I've pushed the car pretty hard on occasions and have had no blow by. Yeay. My catch can is a fully poxy drift one. (from autobahn)
I bought it the day I picked up the car to get rid of the evian bottle and garden hose to avoid a yellow. So for the mean time I put another 5/8" fitting reversed inside the can and ran it to half way in the tank and and cut the internal s/s hose at 45* so it would filter fumes and still had room to dump oil. Will fab up a new one and plumb it in properly from Ali when I have the time. (NEVER) :-(
  • Like 1
I work:
Monday: 8:45am - 6:00pm
Tuesday: 7:45am - 5:00pm
Thursday: 1:00am - 9:00pm
Saturday: 8:45am - 5:00pm
Sunday: 11:00am - 5:00pm
That doesn't include mandatory morning meetings, and customers not getting the f**k out on time.
My roster very rarely changes, but just in case always double check.
Edited by Manne
  • Like 2
Put the whole lot in new then braked reasonably hard 80-20, 100-20. Only p/s squeal. I mainly chamfered the lead and trailing edge at about 30* with a fine cross cut metal file and just took the edges off very minimally. All good now. Just hate doing a job twice. F##* might not have stood on it hard enough.
Did u check if it was a 5/8" or 16mm fitting? Just put a rule on it like the pic I posted and check the pipe o/d (outside diameter) not the swage diameter. Let me know. I would assume it is but always check.
I was worried about the abs juddering on the new rotors and pads if I hit it too hard so was just a guess.
Try nissan. I've replaced with genuine before and don't remember getting raped
It might pay to put a tiny bit of permatex on the corners and rear. Especially if its leaked bad off the rear exhaust cam side before. This will cop a lot of heat because it is near the manifold, turbo and dump pipe. Just a thought. Check there is no gouges or issues around where the leak was and it seats and Seals nicely. Pay attention to the fit up and get everything hard finger tight first then cross torque the cam cover like you would a head gasket. Clean all of the sealing faces up tidy as with a turps rag and make sure there is no gritty bits hanging around or shit from the rag. Use a soft brush to clean up the inside of the cam covers if it's gritty. Set aside a load of time and don't rush it! Don't know how much mechanical experience you have so just general advice. Nothing worse than dumping the gas pedal to a oily smell. Will be awesomeness once you have finished!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
