I have to go to the pool at least 3 times a week for the back. I normally do excersize and stretches in the hot hydro pool then go to the 25m pool for walking and swimming laps. I've got dodgy knees too and if I walk too much in the pool they ache real bad but it's only Austio arthritis. I was in and out of physiotherapy for years and just pissed it all off did a load of research and found a balance that works good for me. What is the main problem with the knees?
A few of my mates I played footy with had Osgood/slaters and it finished them. After over 200 games of footy I wish I'd never played but I loved it alot. Football is my family's religion! But I've lost interest over the last few years. Not as hardcore as t-revs with his West coast Eagles engine bay!
Yeah not bad. How was the drive home car still good and did ya hav3le a grin going home thinking I got a 12 sec car
Hey Dean I found a awesomeness little R35 on Gumtree for the boy. Would post the link if I knew how. Have you got any of the r/c's up and running?
  • Like 1
1 hour ago, Beyond Blue R33 said:
DSC_0348.JPGDSC_0347.JPGthe earlier time was the faster. Dropped it to 30 psi all round today. Do you think the duramax 75-90 is the right oil for the diff? It was juddering bad when I changed it then came good with the l.s.d. Paste and figure of 8's? The tein basics have only height adjustment and the ride is hard as since I lifted I't?
Track temp definatly didnt help, colder it gets the less sticky it becomes and less traction u get. Same principle when its too hot.
Diff oil sounds about right, was the old oil burnt? Id day that the shock from spinning the tyres to it gripping proberly caused it to tighten up through heat. New oil and a some maneuvering always helps.
Ur shocks are gonna have more travel due to increased hight, more fluid to move bk and forth within its stroke which will make it feel harder
  • Like 1
Hmm makes sense, that's what I was thinking too much extension and not enough compression in the shocks which would coincide with the longer travel and higher spring rate. When you gradually build up the boost and launch it sweet on the street is the only time you notice it. The old diff oil was clean as. I was also thinking due to getting cold between runs that it was at its minimum viscosity but the thinner the oil it should make its way into clutch packs better?
I watched footy in high school and early twenties. Now I despise it. I'd rather watch netball or lawn bowls
  • Like 2
i watched WM on youtube. there is 26 x 22minute episodes plus there is a movie
i enjoyed the series more than i expected. initial D was better but its still very good. the movie isnt bad from memory either
  • Like 1
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
