one more early morning then i finally get a sleep in.
gotta finish modifying my chimney so i can start lighting the fire... so bloody cold lately
Yeah I've got a old Jarrahdale wood fire too. I normally run a pedestal fan on it like a supercharger. Even when you close the valves it makes for a way better combustion chamber (hemispherical) and dissipates the heat round the whole house. The performance is amazing from a two valve heater. Surprised the cat hasn't caught on fire he's fully old and loves that sh#t.
ive got a double doored model in an enclosed brick chimney in the middle of the lounge room. ive put vents in at the ground and top to circulate over the fire and get the extra heat back that i lost last season up into the roof. last season we got none of the heat from the top or sides... it all escaped away.  ive already cut out the bricks, just need to finish the vents then plaster up.
A dogs leg in the chimney is also a good fix and helps the chimney hold heat especially in a two story. I'm a sheety by trade and what you've done sounds awesome. Check out TheBlackNobility Charles hotel on you tube. Last gig I ever played. The guitarist was insane and teaches at cosmic.
You've inspired me to get back on the Roland and have a crack. Through the 901's and subs of course!
1 hour ago, Beyond Blue R33 said:
Coolness I played drums in bands round Perth for 20 years. What guitars/amps do you have?
BC Rich Warlock - Afterburner
Peavey Amp - i forget the model but its nothing flash
2 hours ago, t_revz said:
need to walk around the house doing figure 8's to sort it out
any advice ideas for the diff? What bands have you played in?
sorry got no advice. Corey is the man you should talk too
never played in a band. just learnt a few riffs etc and i play Rocksmith sometimes too which is pretty fun
Cool like Kerry king from slayer. I've got a mega old pearl. DW pedals. Paiste 2002s and the old Frankenstein writing paiste sound formulas. The 2002s are the same as Bonham, moon and Ian paice from deep purple used to play. I've met Ian paice, Dave lombardo, zak Wilde, jojo Mayer, Dom famularo, Jimmy degrasso, sepultura, and what not I used to be pretty good and have a few signed drum heads at home.!!!
Cool like Kerry king from slayer used to play
  • Like 1
DSC_0351.JPGDSC_0352.JPGDSC_0353.JPGDSC_0354.JPGwas so lucky to meet Jeff hanneman before he died. He was totally drunk. Haha. I met cyco myco from suicidal tendencies as well. Haven't played in anger for about 5 years mainly due to being old and the knees. can't be assed dragging the kit around anymore anyway. That's mainly why I wanted to join Sau. Missing playing in the bands and wanted to talk to like minded people about the car. I'm no mechanic but love nuts and bolts!
4 hours ago, Beyond Blue R33 said:
Hmm makes sense, that's what I was thinking too much extension and not enough compression in the shocks which would coincide with the longer travel and higher spring rate. When you gradually build up the boost and launch it sweet on the street is the only time you notice it. The old diff oil was clean as. I was also thinking due to getting cold between runs that it was at its minimum viscosity but the thinner the oil it should make its way into clutch packs better?
Winding the coilovers up wont change the spring rate, there fix at the manufacturers spec. Further travel is made harder by more fliud transfer, now u have more fluid either side of the piston its harder for the piston to move.
Made ur diff has seen better days? Our cars arnt exactly spring chickens. Years of abuse and the diffs is saying "no i dont want to" lol or on the other side of the scale mabe its not been used hard enough so wasnt quite working as it should? My mates vn ss had a issue with the diff, wouldnt put any power down just spun one wheel. Changed the oil and took it for a sqirt around the block trying to get the diff to work and all of sudden it just did, locked up and holy crap it hauled ass. Been fine ever since and leaves 11's if used in anger
DSC_0351.JPG.7dc9fb5485cf94c8eac465942b1b0b8b.JPGDSC_0352.JPG.4a11989d0932ed0cff057b4f9c12fd05.JPGDSC_0353.JPG.e8ac078d64d94c697bfe745507386499.JPGDSC_0354.JPG.9218eaa87696055a3ecbe0cf62cf6136.JPGwas so lucky to meet Jeff hanneman before he died. He was totally drunk. Haha. I met cyco myco from suicidal tendencies as well. Haven't played in anger for about 5 years mainly due to being old and the knees. can't be assed dragging the kit around anymore anyway. That's mainly why I wanted to join Sau. Missing playing in the bands and wanted to talk to like minded people about the car. I'm no mechanic but love nuts and bolts!
The top drum head is a used one signed by Dave lombardo (slayer) The second I got signed from Ian paice (deep purple). The last one is from when sepultura toured in 99 the whole band. I scored the Ian paice for the father in-law and he had it hanging in the living room up till he died then was given back to me. Got another pair of sticks signed by will Calhoun (living colour)
Cool thanks for the advice. The rears were bald inside when I got it so no wonder it torched them both evenly. It performed well today on the street. The car is at 3000rpm at 110 in 5th which is pretty annoying so I would assume it has 4:1.1 never had any issues till I lifted I't and changed the tyres. By the way it behaves I'd assume it's a 1.5 way l.s.d. Alot of people reckon the Achilles atr sport 2 are slippery tyres so should spin both easily. I checked all the mounts and bushes when it was up on the hoist at my mates work about 3 months ago and they seemed all good? More crawling around on the back required! Should be easy to fit in around 11hr days at work. Building a silencer that has dual 6" inlets to a 10" outlet 30" diameter 96" long. Double laminate 3.2mm thick body. Back is sore, I am old. I did the diff oil ride height and tyres all at the same time so makes it a bit harder to trouble shoot when it was all good before?
DSC_0166.jpegnot your every day muffler!
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
    • Good work Pete and glad the car held up well....been a while since I've seen you try properly
    • Just quick update, I've had tech issues and so a backlog on life stuff....I will pull lap times from the video and data from the ECU logs to do a proper update. But basically, in order of importance: 1. The car was excellent fun on the track, really felt a lot like the good old days. And nice to have AC while waiting 2. Coolant got really hot; again I need to pull and analyse the logs but the standard system is not up to tracking at 30o+ days, once the system was heat soaked after the first 2x15min sessions I could only do 3 laps before it got 110+ and I had to cool down. If I can't improve that it is a deal breaker 3 Oil temps were fine all day, noting it was short sessions due to 2. I think it will likely need work 4 Biggest surprise AT temps were fine, never went over 100, I would have been OK with 120 before I was too concerned. The auto sucks compared to a manual (of course) but it is faster to launch and I just need to downshift it manually before hitting the throttle, then it was OK. When I post the vids you'll hear it telling me off (beeping) for trying to downshift too early (it needs about 3500 before it will downshift, depending on gear a little but we are mostly talking 3/2 and 4/3) 5 A052s were not great which hurt the lap times, but I will be constrained in what I can get in good tyres that fit the wheel wells. These were small for a heavy car at 235/45/18. In theory I can fit 9.5 on front and 10.5 rear (so not square) but I still need 670mm+ high tyres in good brands. 6 Standard shocks/springs/roll bar are too soft for track work (of course), but that was always on the list. And happily, no white on the mat, despite having a teenaged passenger, extinguisher mount was fine. Also, it was nice to have Wakefield Park back in action  . Because the car was so quiet it is eligible for Green Day, which I thought was a band but is apparently a series of cheaper practice days they run with a lower sound limit, that is a smart idea.
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
