1 hour ago, Beyond Blue R33 said:
Post some pics when you've finished? The work you have done sounds top notch. Wouldn't expect anything else after seeing the engine fit and engine bay pics. You're a animal!
quick diagram of it. the only thing that isnt complete is fitting the ducting from the ceiling enclosure to the bedrooms. i was thinking about using 100mm stormwater pipe to each room but now im after 100mm steel piping to use instead.
  • Like 1
Insane. The tubing system should be 0.7mm s/s crimped and swaged. Dual 45* off the main flu would be better than a 90* t piece for draw. If it's running off at 90*. A dogs leg in the insulated flu section would help the heat stay downstairs and run off to the rooms better. The storm water pipe would melt and should never be used for this application off a wood heater. 0.7 s/s crimped and swaged inside insulated through the walls and roof. The storm water pipe would only be good for a reverse cycle system and is totally inappropriate for a wood heater.
when i tested last season the enclosure temp was only 40C max. now that the bottom section isnt insulated the temp is much higher and i have to change to steel.
where can i get 100mm steel pipes at a reasonable price? think gutter down pipe is only 70mm.... flue piping is probably too expensive....ideas?
We have m.s.t. and s.s.t. at work it's 101.6 mm o/d (4") and 1.6 mm or 16# thick (for exhaust systems) 70mm would be 2 3/4" o/d. And the same thickness. Most stuff to do with heating and flues is 304 s/s 0.7mm thick because of its heat transfer properties. We sell it by the metre in s/s and m/s at work (the 16#) If you know what you want and let me know will be cost price:-) or Jarrahdale heating and cooling or perhaps kounis metal industries have the crimped lapped and swaged 0.7mm at God only knows what price. Will post a pic of the 0.7 crimped and swaged from my heater.
cheers, a rough price on mst 4" would be good thanks. no idea how much i need yet but say 20metres at a guess
just found stratco sells zinc downpipes in 10 different sizes including 100mm. i dare say it will be pretty cheap as its so thin 0.4 or 0.5mm
Perfect would be way cheaper than s/s or a heavier guage. The zincalume will last for ever indoors.
Maybe just get one length check how hot it gets? you could lag it where it's near wood gyprock etc. With needle felt fibre glass or the fibreglass roll tape stuff. Or anything else that is itchy. Man I hate lagging stuff up.
due to smaller ventilation holes to the top, plus the top section being an insulated flue the absolute max i would expect coming out of the enclosure is 60C and could possibly be only 50C. id rather have metal pipe from the enclosure down to the fans but it shouldnt be that hot that i need to keep it away from timber etc...
as always i test very thoroughly and i will know the actual temp next days off and build it with a higher than actual temp spec in mind
yeah i thought it would prob be cheaper. thanks anyway
Salvage yard if stratco arent cost effective?
What about the silver foil backed stuff for under metal roofing?
On 5/12/2017 at 1:47 PM, colin.ssc said:
@Hank Scorpio recommended camber arms brands? Thinking of getting F&R set for the 36 but not sure if the cost of getting it is of any benefit lol
I like Japanese stuff, Cusco and Kazama are always good.
  • Like 1
https://www.bunnings.com.au/earthwool-r-1-3-55mm-18m2-space-blanket-under-metal-roof-insulation_p0810887
This stuff, would just need to use foil tape to seal it around the pipework.
Looks very itchy so would do the trick.
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
