I like Japanese stuff, Cusco and Kazama are always good.
I've been meaning to pick up the Cusco rear brace that goes on the back of the 33 strut towers just because it looks better than the top mounted one and matches the front. Without modifying the rear parcel shelf. I put some new rear alpine speakers in the back a few weeks ago and it was a hassle to remove just for speakers. Any thoughts/opinions on what would be the best? I would assume that the top would be the best for rigidity and strength to match the front and the rear for body rigidity? Love the look of the Cusco stuff.
Seems no one is too interested in car talk? I bought a sushi roll a few weeks ago and wished it was a t-bone steak or a t-box or a x-box?
I'm looking at either a Kansai or Autoselect brace for my front and what ever for the rear. Finally got around to rebuilding my front hubs/struts/brakes last night. Time to look into doing the rears
Lol, these were posted 2 hours between each other?
Haven't had much personal experience with rear tower braces an a 33, can't imagine you're going to notice much of a difference between the 2 styles. Which ever one is easier to fit/will work for you.
On 5/20/2017 at 10:19 PM, Beyond Blue R33 said:
We have m.s.t. and s.s.t. at work it's 101.6 mm o/d (4") and 1.6 mm or 16# thick (for exhaust systems) 70mm would be 2 3/4" o/d. And the same thickness. Most stuff to do with heating and flues is 304 s/s 0.7mm thick because of its heat transfer properties. We sell it by the metre in s/s and m/s at work (the 16#) If you know what you want and let me know will be cost price:-) or Jarrahdale heating and cooling or perhaps kounis metal industries have the crimped lapped and swaged 0.7mm at God only knows what price. Will post a pic of the 0.7 crimped and swaged from my heater.
suprisingly, 100mm zincalume downpipe is not cheap from stratco.
$75 for 2.4m
  • Like 1
@z00key  if you dont mind can you check out what these are worth. thanks
Beko DIN38450 14 Place Setting Fully Integrated Dishwasher
Model: 837624  SKU: 837624
Asko D5536FI Fully Integrated Dishwasher
Model: D5536FI SKU: 721345
Asko D5546FI Fully Integrated Dishwasher with Cutlery FlexiTray
Model: D5546FI  SKU: 721346
$75 for 2.4m
I will get you a price on a 3m 4" o/d length m/s and s/s from work which would be 16#. but would assume even at cost price would be expensive. I only build the stuff so have no idea on pricing. The price is saved by using the thinner guage material (0.7ish) and having the proper forming machienes like stratco. Loads of heater shops will carry it in the 0.7mm s/s but like stratco at a profit. I was going to use some 5" 16# tube a few years ago or same stormwater pipe filled with concrete so I could paint it with with marble paint look for AWSEMONESS on my gazebo but just got 100mm square posts sanded them back and stained them in Japan black because was going to cost a fortune in steel or pipe and concrete?
ill hunt around tomorrow for a better deal. surely someone selling the thin 0.7mm stuff has it cheaper than that.
im also going to get the fire at its absolute max with heaps of small stuff and find out the absolute max temps im going to encounter so i know how much metal pipe i need before i can change to PVC.
  • Like 1
Max it out. R+D. Your a animal!
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
