no.
fuel or ignition, fuel cut is the go to default as its softer. ignition cut gives pops and bangs (and on an RB isnt great for the oil pump) and is harder.
powerfc does fuel cut for the limiter, more advanced computers can do either or both as steps (eg kill fuel at 8k and fuel and ignition at 8.5k)
  • Like 1
no.
Why oil pump dont like it ?
Im thinking of detonation as i did hit 66 knock at 7950rpm pop pop pop.
I have dejetro i have map no AFM
The only one for ign cut in PFC is pfc Pro n it has launch control too.
Im intrested in how launch control is done and how much more its helpfull
Because the oil pump drive off the crank gets smacked around like a hammer as the ignition cut limiters are generally faster to cut/resume and this eventually cracks the gear in your oil pump losing oil pressure followed shortly by the rest of your engine and turbo dying.
Launch control depends on the ecu, some are just a 2ndary limiter, some do ignition retard and add fuel to build boost. If you have a gtst. Launch control that builds boost is fairly pointless as it just results in wheel spin.
Full grip baby GT-R style [emoji12]
Then it makes more sense.
But be aware that it's not nice on your gearbox/clutch/drive shafts. Revving the car up to 4k and dropping the clutch isn't nearly as likely to break things as Revving the car up to 4k, building 20psi and then dropping the clutch.
It's really a show off thing or drag racing thing, other than making turbo noises at the lights or in carparks it has no practical Street use.
4k and full boost yummm.
I attempted learning to do smooth launch 7k drop clutch swiftly.
But still smelt clutch now paranoid about clutch life left.
Anything under 7k i bogged down. May -5 turbos not helping
I hit 300 knock once. 91ron fuel
Good times
Our pumps came with a hex type shape that cracks on the corners and it didn't sit fully on the crank on earlier models so the edges get worn making a loose fit.
I fitted a collar to my crank to rectify but mobs like tomei use a spline instead of the hex
  • Like 1
Good times as in rebuild?
Only 1 piston didn't have broken ring lands when I rebuilt but I'm unsure which incident broke them. It was overheated twice. Knocked to 300 once and ran so retarded once that the exhaust manifold snapped,all studs broke, turbo shaft snapped and engine harness melted
But I rebuilt it 3 years after all of these events so it held up well [emoji12]
Wow that a decent effort.
So did you do a spastic rebuild or a normal one.
Same crank, forged JE pistons, spent a heap on port/polish and modifying the head. Tomei cams,springs,exh gear. New turbo and all the associated supporting bits.
Best case should do about 450hp at treads on 98 or into the mid 500's on e85. Hopefully get it going within a week. Needs a new alarm system
Is it worth the money on the head. Coz that the area i 1st want to mod.
It's not one of the things you need to bother with at the power level -5 will give you. Small duration high lift cams are a better spend (~260 deg ~10mm)
  • Like 1
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
