All good till the government rips the ass out of what you have earned from busting your balls. Wow look at, oh, bummer.
Yep always paying the man
I've made 10-11k a fortnight plenty of times when they offer unlimited overtime but I think from memory I only end up with 6k
I feel you on the mega overtime. have done some 26-28 hour days. Get home, pass out on the couch for a few hours and then wake up for some dinner. Far from a good time.
That's the go, getting work to pay 26-28hours for a 24hr day
  • Like 1
Any updates?
It has been quoted, assessor to review then I will have an answer, it seems like it's repairable, we have discussed our tidy up [emoji14] the 34 will be very tidy after this I'm sure [emoji6]
We have a couple of ideas that if we go ahead with will really set the car apart from others [emoji108]
  • Like 2
Suicide doors and 24" mags?
  • Like 2
13 hours ago, shoey85 said:
It has been quoted, assessor to review then I will have an answer, it seems like it's repairable, we have discussed our tidy up emoji14.png the 34 will be very tidy after this I'm sure emoji6.png
We have a couple of ideas that if we go ahead with will really set the car apart from others emoji108.png
Ooooo sounds promising
Was thinking of strengthening the front a little and running a new cai
5F021C56-AA04-40BE-AE4F-270AAE88264A-1514-0000019928DF801A.jpg.b41678dceae543f796def36451ce8707.jpg
That will make it 2 of a kind then.
Fully equipped to bash roos and do water crossings. Traction and water ingress might be an issue you want to look into though.
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
