There isnt a whole lot of info on rb30dets in my desired relms of use. Most rb30dets area drag monsters...
Hmm suppose it's the difference between a punchy quicker less laggy spool or a wait for a bit and get the the the holly f##k on it scary spool. Response vs shear power balance. Loads of rb's you see with bigger turbo's tend not to be able to get off the line or blow up boxes half shafts and diffs. I'd say with the bigger turbo you would need a mental clutch and longer ratio to get the power happening or it would just snap stuff and light up the tyres permanently. Which is also fun:-)
6 minutes ago, TiTAN said:
High flows have been tried on an rb30 years ago. It was a cheap build basically stock Na bottom end with the 25 head and it came on like a light switch but come 5000 it hit a wall, by 5500 it had dropped about 100kw from memory.
This is no gd... mine will be a forged bottem end so looking to lean on it some ?
Being a 3ltr it will have more torque anyhow so perhaps response is the way to go? Don't forget I'm only a sheet metal worker who has never blown up a Cleavo Windsor c4 top loader or 9".[emoji4]
Gtx3582r with an 50mm external gate is what i was also thinking. Either way i think external gates gonna be better
I had a pre gtx series 35r with 0.82 rear. If you tweaked the waste gate setup you could have 20psi at 3500. Traction was non existent below 100km/h, for Street use it was too laggy to be quick and too fast to be usable without potential jail time. You would start seeing positive boost (a few psi) at 2500 with a bit of load.
Guilt-toy had a similar setup and should be documented fairly well on sau.
This is my dyno sheet, 26 psi and the dip at 145 was spark breaking down, done on a 33c day.
13 minutes ago, Beyond Blue R33 said:
Being a 3ltr it will have more torque anyhow so perhaps response is the way to go? Don't forget I'm only a sheet metal worker who has never blown up a Cleavo Windsor c4 top loader or 9".emoji4.png
I hear u can get cheap pipe? Gonna need some mikd steel and aluminium to make some pipe work. Proberly not till later in the year tho
  • Like 1
Hell yeah, that looks right up my street. I wont be using it much on the street, mabe once a week at this stage. Il proberly get hooked at drive it all tje time lol
thats a run out at an airport, i am not even an amateur film maker obviously as its hard to even read any of the gauges. had spark breaking down at 160 then it clears up and keeps going, trapped at 242km/h at the 800m mark.
  • Like 1
Sounds gd ?
16 minutes ago, TiTAN said:
That's mainly to give you an idea just how quickly 400kw puts on speed.
If it's going to be a track toy, you are going to need some serious brakes to deal with stopping it. Upgraded pads and rotors won't cut it.
350 all round. Alpha omega brembo upgrade. Dba discs and bendix pabs. With all my cars its always been suspension, tyres, brakes then power.
Posted some pics of the boot fit out. What do you think of it?
Looks good mate, should sound good too.
A lot of bass is lost through the back seat of our skylines due to the steel plate etc but will still be plenty of punch no doubt.
Is it all hooked up and running now?
  • Like 1
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
