On 28/09/2017 at 11:11 PM, Manne said:
I don't want to be that guy, but, I was taught that you're not supposed to buff a car for at least 3 months (normally 6) because the paint has to de-gass.
Most paints are water based now, takes no time to dry these days....
42 minutes ago, TiTAN said:
When did you stop being all for men hugging in fields? I thought that was your 4th favourite thing to do?
Was till he ran outa lube... i think hes still soar and chaffed from last time
11 hours ago, TiTAN said:
I thought it had to do with letting the paint finish hardening before you start cutting into it with polishes as it's still technically "Soft" for a while after its dry.
Think of paint like skin, kind of. When a car gets freshly painted, or when you buy a new car, the paints generally still in a stage of de-gassing, where all of the gasses from the paint are slowly releasing. If you start covering it in polish/wax,  you clog the "pores" on the paint and get imperfections.
I've always been taught not to wash a car for 3-6 months after a paint job, although some paint shops have developed baking techniques to get the gasses out faster.
Ovens a pretty technical these days, my mates blow dries the paint inbetween coats then bakes it a different heat settings over a set period of time.
  • Like 2
On 9/21/2017 at 12:22 PM, Stinky Rooster said:
I would rather douse my genitals in hot sauce before dragging them through broken glass and razor blades, than drive a magna
Actually, I might do that anyway
results to be posted
  • Like 1
So technical. I was thinking if you just went really really fast the air would dry it out?
  • Like 2
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
