On 28/09/2017 at 11:11 PM, Manne said:
I don't want to be that guy, but, I was taught that you're not supposed to buff a car for at least 3 months (normally 6) because the paint has to de-gass.
Most paints are water based now, takes no time to dry these days....
42 minutes ago, TiTAN said:
When did you stop being all for men hugging in fields? I thought that was your 4th favourite thing to do?
Was till he ran outa lube... i think hes still soar and chaffed from last time
11 hours ago, TiTAN said:
I thought it had to do with letting the paint finish hardening before you start cutting into it with polishes as it's still technically "Soft" for a while after its dry.
Think of paint like skin, kind of. When a car gets freshly painted, or when you buy a new car, the paints generally still in a stage of de-gassing, where all of the gasses from the paint are slowly releasing. If you start covering it in polish/wax,  you clog the "pores" on the paint and get imperfections.
I've always been taught not to wash a car for 3-6 months after a paint job, although some paint shops have developed baking techniques to get the gasses out faster.
Ovens a pretty technical these days, my mates blow dries the paint inbetween coats then bakes it a different heat settings over a set period of time.
  • Like 2
On 9/21/2017 at 12:22 PM, Stinky Rooster said:
I would rather douse my genitals in hot sauce before dragging them through broken glass and razor blades, than drive a magna
Actually, I might do that anyway
results to be posted
  • Like 1
So technical. I was thinking if you just went really really fast the air would dry it out?
  • Like 2
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
