I did and tried to call him , must be dating.
All I need is the bush brush but sadly it’s not separate item
, come with the arm. Not in rush , I prob can pick up straight from Japan. And I have a friend who works in nissan Wangara who can install it for me
For 1700 go to Japan and get one [emoji2]
  • Like 1
2 hours ago, ElleAli76 said:
After market? Nah I’m looking for genuine parts , it won’t last long with after market plus it’s stiffer !
Aftermarket is always better.... why fit a hks exhaust if the nissan one is better? Lol
  • Like 1
Now with the exhaust is different , I didn’t go with Chinese brand like what I’ve got now and FYI I didn’t have that install it was from previous owner , it’s still loud but I don’t like it as it didn’t sit very well.
With genuine Nissan’s exhaust yea it’s good but it’s not loud enough like how I want it.
So I go with HKS , it’s loud enough than the current.
Now questions - do I need to re-tuned the car with the new exhaust ? What about the horse Power , would it impact ?
  • Like 1
 A tune is always gonna improvw things, boost + ignition + fuel = power!
Edited by R33kizza
Any internal spare parts Or engine oil I’ll go with genuine , accessories feck I don’t care , so long it’s good quality and kot Chinese emoji28.png
Are u planning on lowering the car? If u do ul need those bushes to compensate for the added camber...
  • Like 1
Nah not really , it’s the clanking noise that I can’t stand and apparently I need those bushes
lol it’s drivable tho , it’s not like a safety concerns. Anyone wants to help me ring japan Nissan’s and found out how much ? My Japanese skills are very limited [emoji23]
Sounds like a task for@t_revz
  • Like 2
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
