IMG_2227.thumb.jpg.6ffb113aec7b9a95669074f759c650a1.jpgIMG_2286.thumb.jpg.fed3c3425a6ef6b4041817ff45a91208.jpgIMG_2284.thumb.jpg.5275d12b4b0d77f9002fafe6f230819b.jpgIMG_2282.thumb.jpg.30d3c68bef6802152a8556eae3bf1200.jpg
Eye candy for you boys !
Bought my spare parts for $250 AUD !
Back home Josh wants $1700 , Nissan’s $2200 and I paid 26k Yen ! So how much is that in AUD [emoji23]IMG_2274.thumb.jpg.217186a957d4d861c9910139fbfb6d51.jpg
So jelly your in Japan [emoji627]
  • Like 1
Wanna come and swap dave’s place ? Hahahahah I think we Might have to cut the Holiday short as Dave are not Feeling well , his nose Bleeding none stop Since we arrived ( cauterize )
We Catching up with few friends today , to take him to the hospital.
Wanna come and swap dave’s place ? Hahahahah I think we Might have to cut the Holiday shorter as Dave are not Feeling well , his nose Bleeding none stop Since we arrived ( cauterize )
Bugger hope he gets better soon!
  • Like 1
my xmas bonus was being asked to come back on the 2nd instead of the 8th........
ahh the life of the scumbag mercenary contractor, how I have missed you.
Doc has laid down the law that I cant get back on the bike till march, so I'm now getting full on planning for some mods, looking for opinions.on direction
flat track / rat racer
01.jpg&key=72f68c476db4e391d7a695be159d6aaf4b03c9121ce37f7ae802c9ece5a0ba6a
street scrambler
a7d552e1562733cbd548e9a76627ad83.jpg&key=ecc28356e4160e961950450d6f8bc0e5ff73227f6055a2f8f411ff9a434824ff
or super motard
a87da3efdde383267a7c21b157470137.jpg&key=c449d6a03ae32ce1bed76d04d44ba42c2f796e9e6cca5edaa02516c688fea7c9
thoughts?
The weather is nice today would be my current thought. My one before that was how much I was enjoying my sausage rolls for lunch.
Jam a couple tampons up there [emoji12]
  • Like 3
Bummer Dave. That sucks.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
