6 hours ago, ElleAli76 said:
When I was in Nismo Factory I asked the GTR mechanic regarding the clunking noise came out from my car , he gave me this and he reckon it’s not the bushes , I need to clean the IMG_1515132234.801114.jpg
Parts that he circled shows on the diagram. Dave said he can do it but he won’t take the risk , who can help me with ? Lochy ? Or josh ?
I can do it for you? I was trusted with a $400k m760li today ?
  • Like 1
2 hours ago, t_revz said:
Anyone know if point to point cameras check rego expiry?
Depends on the system, its either conna pick up ur rego and speed and bill you for exceas speed or ita gonna do that and flag up to someone somewhere that the rego is expired
Looking at the pic it looks like he wants you to clean and lube the hubs. We have to do the same thing with the x5m's as the make a horible cracking sound otherwise
Yup ! That’s what he said to me , Let’s give that a go , when can I drop the car ? And what’s your mobile number ?
All I have posted a new cruise in the events section, your feedback is welcomed.
Hills and a feed January 2018 Cruise
https://www.sau.com.au/forums/applications/tapatalk/index.php?/topic/473053-Hills-and-a-feed-January-2018-Cruise
  • Like 1
Good work. Hope you get a good turnout
  • Like 2
Only $684 to get to Japan near the in laws if we travel this year.... very tempting
Book it ! That’s so cheap and I still have ¥80000 in cash [emoji383].
We’re going back in 2020 summer Olympic
Hopefully we will be there for the Olympics too. Need to sort accommodation
  • Like 1
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
